install nidaq.dll/nican.dll fail on the win7 64bit system
I am using labview 2019 win7 64bit, when call nidaq/nican.dll, it shows need 64bit dll not 32bit, how to fix this issue? thanks
(2,185 Views)
Are you using 64-bit or 32-bit LabVIEW?
Did you install the drivers to match which bit-version you are using?
Normally, people use 32-bit LabVIEW even on a 64-bit version of Windows and would install the 32-bit versions of the LabVIEW drivers.
(2,171 Views)
