Showing results forĀ
Search instead forĀ
Did you mean:Ā
installer build giving error code -12
so, it is a problem of how you configure the installer or configuration of LabVIEW.
Can you post that simple project to have a look at it?
I.R.
Message 11 of 18
(1,659 Views)
I don't even come to the configuration. I only choose new installer and then the error pops up. I attached the project.
Kind Regards,
Grega
Message 12 of 18
(1,657 Views)
Hi Grega,
I manage to build an installer with the project you've attached.
I am reattaching it with the Build specification already defined, try one more time just to right click and build, if it still fails, for sure it is a problem with Application Builder. The best would be to reinstall it.
What version of LabVIEW are you using? 2012? Proffessional? Full Development??
I.R.
Message 13 of 18
(1,640 Views)
Hey ion.rosca,
I am using version 2011, professional development system. Could you save project test as 2011 version? Thanks.
It looks like it is a problem with the app builder, since I don't even get to the configuration dialog upon choosing new installer.
Kind Regards,
Grega
Message 14 of 18
(1,635 Views)
You could reinstall the Application Builder, and it should solve the problem.
BR
I.R.
Message 15 of 18
(1,632 Views)
Yep, I get the same error. I'll try re-installing the app builder.
Thanks for everything,
Grega
Message 16 of 18
(1,630 Views)
Hmmm, I tried reinstalling the app builder by inserting the CDs with labview, but I didn't find app builder to install or reinstall.
Is it maybe inside of some other feature?
Kind Regards,
Grega
Message 17 of 18
(1,625 Views)
Hello there, is this tread have been solve? i have a similar problem as the picture attached. Can anyone help me to solve this, i am using labview 2011 professional version
Message 18 of 18
(1,575 Views)
