installing older versions of labview after newer versions.
I Just installed LV 8.5 (dev suite) on clean machine.
Notice that 8.5 will not read LV 5.0 VIs.
I Would therefore like to install LV 7.0 (dev suite) (over the 8.5 installation).
Any known issues?
(2,821 Views)
The only problems you might have is if the older apps required one of the add-on toolkits. There were very few toolkits for 5.0 so I doubt that would be much of an issue. You should not install any of the hardware drivers that come with your 7.0 distribution.
(2,807 Views)
Moreover, you may encounter problems with the run-time engine when you build the EXE of LV7.0 code & try to run it in the same PC. It may/will say that the application requires an old run-time engine to be installed to get it running.
Always it is better to install from an older version to a latest version.
- Partha ( CLD until Oct 2027 🙂 )
(2,803 Views)
