instances
Hey friends,
                                 Can you please tell me that to acheive the reentrancy do i need template vi. If i create the reentrancy using normal vi than what parameter will change in terms of performance & speed ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 16
(1,412 Views)
@Ranjeet_Singh wrote:
Hey friends,
Actually, a regular reentrant VI will be faster than loading a template.
Message 12 of 16
(1,403 Views)
Than which is the actual application where .vit leads .vi ?
Initially i was acheiving the reentrancy using .vit file but now i think .vi is better option than .vit...
Can you please send me some link where i can read the properties of .vit file.
Thanks.
--Ranjeet
Message 13 of 16
(1,396 Views)
Here's a conversation we had about the subject over on LAVA:http://lavag.org/topic/15640-asynchronous-call-takes-long-time-for-vit-files/page__p__94545
Message 14 of 16
(1,392 Views)
HI crossrulz,
                                   Actually i read this arcticle & changed the called reentrant vit to reentrant vi. I dont know the actual reason but my called vi is of 70KB than also first call take 3 - 5 sec to load(to show the front panel) but from second call it opens immediately ?
Any suggestions ?
--Ranjeet
Message 15 of 16
(1,368 Views)
Hello all,
                   I reached anoter step towards & getting one problem again. I posted as a question here.
Can anyone want to take a look at it
--Ranjeet
Message 16 of 16
(1,352 Views)
