instrument I/O issue
I am receiving data from an impedance analyzer using a GPIB interface.  The data array comes into the VI via instrument I/O assistant block.  The problem is that the array contains two plots.  The first value corresponds to plot A and the second value corresponds to plot B(see diagram) and they then alternate.  I need to get A and B separated into to separate arrays so I can plot on my VI.  Does anyone have any suggestion or solutions?
Eric
[123; 1234; 120; -1233; 134; 1223]  =>   [123;120;134]  [1234; -1233; 1223]
  A        B      A       B        A      B                      A                           B
{ incoming data array}                            {two data arrays formatted for plotting}
(2,382 Views)
The Decimate 1-D Array function can do what you want. You may need to be careful about synchronizing the data between successive reads. If the instrument has a "verbose" mode where it send the name of the channel along with the data, that can be useful for the parsing.
Lynn
(2,379 Views)
That was an easy fix. Thanks
Eric
(2,375 Views)
