instrument driver
I was trying to connect TEC-9100 to Labview but I couldn't find the right driver. I tried to in IDN no luck.
Message 1 of 13
(5,777 Views)
You mean IDNet? You're right, there isn't one. That device apparently uses Modbus, so you can use the Modbus library to talk to it.
https://www.ni.com/en/shop/labview/introduction-to-modbus-using-labview.html
Message 2 of 13
(5,772 Views)
I am very new to this Labview, and I have try to communicate this modbus with labview but I couldn't. Can you suggest a good place that I can start from scratch?
Thank you
Message 3 of 13
(5,756 Views)
Did you read over the document for which I provided a link?
Message 4 of 13
(5,751 Views)
Yes I have read that and tried to add some examples following this link
file:///C:/Documents%20and%20Settings/gebiurg/Local%20Settings/Temp/readme.html
and this
http://zone.ni.com/devzone/cda/epd/p/id/4756
So far no luck.
Message 5 of 13
(5,744 Views)
Your first link points to your hard drive. Unless you want us to hack into your computer, we can't see this.
Define "doesn't work". What did you try?
Message 6 of 13
(5,725 Views)
Now I have added the Library. I can see modbus. Here is where I am and stuck. I have connected the TEC-9100 to PC using RS232 connecting to RS485 adapter. I am confused now what to write so the LabVIEW can communicate with this device. I was trying to use VISA Open, Write, Read and Close. I guess I am in the wrong way.
Thank you for your help
Message 7 of 13
(5,709 Views)
Is it really that hard to Google 'LabVIEW Modbus tutorial'???
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
Message 8 of 13
(5,705 Views)
It might be hard for you :). I guess you just logged in wanna say whatever you want to say. If you don't have a specific answer for it just at least be just gentle. Please try to Google how to be gentle.
Message 9 of 13
(5,699 Views)
Its tiresome when people don't make an effort to help themselves.
Message 10 of 13
(5,695 Views)
