instrument driver
Accepted by topic author gltfrs
@gltfrs wrote:
Now I have added the Library. I can see modbus. Here is where I am and stuck. I have connected the TEC-9100 to PC using RS232 connecting to RS485 adapter.
Wait, I don't understand what you did here. You cannot directly connect RS-232 to RS-485. The electrical signals aren't the same. One's differential, the other is not.
 I am confused now what to write so the LabVIEW can communicate with this device. I was trying to use VISA Open, Write, Read and Close. I guess I am in the wrong way.
For Modbus you would not use VISA, and I don't understand what prompted you to go there. You would use the VIs in the Modbus library.
Message 11 of 13
(918 Views)
I finally finished this project
Thank you very much all
Message 12 of 13
(882 Views)
Hello fellow LabVIEW user,
I know it has been over five years since your post pertaining to the TEC-9100 labview question, but I can see that you finally figured it out. I was wondering if you'd be willing to share your findings with me as I am working to create a labVIEW program in order to control my TEC-9100 Temperature Controller.
Any help would be great!!
Thank you.
Message 13 of 13
(768 Views)
