instrument io assistant: pass values
Hello
I'm using the Intrument IO assistant to configure some intruments. I would like to know, if its possible to "pass" values to this IO assistant, in order to configure the intrument according to parameters obtained from the main VI
Thanks in advance
(2,430 Views)
This is a feature requested quite often with the Instrument I/O Assistant, and will be available in a future release of the Assistant. Currently, there is not a way to do this through the Assistant. However you can take the generated VI as a starting point and modify the code yourself so that the VI takes inputs as variables.
Hope this helps.
-Tommy
(2,430 Views)
