integrate code in labview
I do not know if this action is possible with Labview but I would among other things, set up a simple code in C outside labview to offer the developer , different parameters to ultimately create a database in the program has adapted needs.
Example, if I want my labview program has say, four external devices , the port is connected to port B with buttons or displays positioned on { x, y } and the conditions of each object are defined according to the need of developer , this would be the C program that define these parameters in such a text file and the text file would fit a result in Labview as import by defining a basic program with connections and positions of each Vi , buttons , displays, ...
To give you a better idea of the thing , I can take an example , home automation , or where each house has its peculiarities to know the number of devices , type, ... which are automatically set by the developer in the C program because it has already defined its needs.
Thank you in advance for your answers
Message 1 of 9
(4,887 Views)
I am very sorry....but: What exactly is the question?
thanks for stating clear questions in the future,
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(4,855 Views)
How to " define these parameters in such a text file and the text file would fit a result in Labview as import by defining a basic program with connections and positions of each Vi , buttons , displays, ..."
Message 3 of 9
(4,847 Views)
Sorry, but you still have to help us in understanding your goal:
As i understand it, you want to provide a configuration tool which lets the user configure some specific topics on the application. This tool creates a file which is then used to create VI(s) matching that definition.
Is my understanding correct?
Norbert
Norbert
Expert: Geometry
Message 4 of 9
(4,830 Views)
Accepted by Fëanor
Are you trying to automatically generate a VI based on user inputs?  The LabVIEW Code Generation Engine might be useful.
Jim
Message 5 of 9
(4,823 Views)
Norbert
Yes and define also the position of Vis, buttons, displays,...
Message 6 of 9
(4,784 Views)
So please look into the link Jim provided.
There is no tool for this available, but you can create one. BUT: This requires a very decent knowledge about LV and "VI Scripting" and hence is nothing, a LV newcomer can handle.
So baseline message:
It is possible, but very complex. The advantage is that the "Script" file (so the file you are talking about all the time) could be "generic" as you have to implement a parser on your own.
Norbert
Norbert
Expert: Geometry
Message 7 of 9
(4,775 Views)
oh... ok thank you. for explain my think,
for example the file to import to LabView is could be a txt file like this:
while ( Loopcondition != STOPBUTTON)
Display=NumericControl*5 {5;6}
I thought something like that.
Message 8 of 9
(4,769 Views)
Do you really need to implement some C interpreter for this? As i understand it, you can just set up a settings/parameter file?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(4,721 Views)
