integrating LV and tclsh
Hello LV'ers,
I am new to LV , so far I  have a basic understanding of LV.
I am trying to integrate LV and tclsh, so that I can pass TCL commands and get data back. I did a brief research and found some  have achieved this by using activex control, call function node but no examples on how to do it.
I would appreciate help on this !!
Varun
(2,654 Views)
Hello Spirit Varun,
I would like to point out this Developer Zone, and the example included in it. Please let me know if this is what you are looking for.
Izzy O.
(2,629 Views)
It shows on how to execute a tcl script from LV, I am looking for on how to keep the tclsh prompt open and send multiple commands and read thier output simultaneously. With this way , I get the total control from LV, and get response from the command instantly not having to wait till the script finishes executing, with this approach everything is integrated in LV which could be part of some other top level routine. In the example approach LV only intiates the script but doesn't keep track or follow after starting to execute the script, I have to manually look at the script results.
I am trying to achieve this : http://wiki.tcl.tk/8496
(2,606 Views)
Hi
I think this forums can help you. In this forum you are going to find other link to different forums that can be useful too.
General information
https://decibel.ni.com/content/docs/DOC-9075
Here you can find other links:
http://forums.ni.com/t5/LabVIEW/TCL-labview-activex/td-p/300347
http://forums.ni.com/t5/LabVIEW/I-would-like-to-execute-a-TCL-shell-and-issues-commands-to-that/m-p/...
http://ni.lithium.com/t5/LabVIEW/Importing-Labview-DLL-in-TCL/td-p/316676
All these discussions should be useful for you.
(2,585 Views)
