integration
Hi HrvojeM,
LabVIEW already has a Mean function…
So you want to average 2000*100 samples?
Message 11 of 15
(2,185 Views)
Basically yes. For every value of the magnetic field or voltage (2000 evenly spaced values drom -3V to +3V) I would like to have only one (averaged) value of derivative of magnetization. I don't need to do 100 iterations, it could be less, i.e. 20.
Message 12 of 15
(2,165 Views)
Hi HrvojeM,
see this thread, it basically handles the same problem on averaging!
Message 13 of 15
(2,152 Views)
Hi GerdW,
thank you for suggestion. I've found a possible solution for the averaging using uninitialized shift register from this link https://forums.ni.com/t5/Example-Code/Waveform-Averaging-to-Remove-Noise-as-an-Alternative-to-Using-..., but have some problems. Should I average both signals simultaneously or just the "time derivation of magnetization" signal? Is there a difference? (the "magnetic field strenght" signal is periodic in time with period of 33ms with no noise, and "time derivation of magnetization" signal is also periodic in time with same period but has some noise). I have attached VI's for both approaches, both of which gave empty "average dM/dt(H) graph".
Thank you for your time,
HrvojeM.
Message 14 of 15
(2,115 Views)
Accepted by topic author HrvojeM
Hi guys,
I would like to thank you one more time for your help and let you know that I solved the problem with averaging with the big help from RyanPoPo. You can see our correspodence here https://forums.ni.com/t5/Example-Code/Waveform-Averaging-to-Remove-Noise-as-an-Alternative-to-Using-....
HrvojeM
Message 15 of 15
(2,019 Views)
