intensity graph: remap x coordinates
I am trying to plot an Intensity Graph which does not have the array indexes on the scale. Instead, I want to map non Integer values to the array indexes and show them on the scale.
For example: I give the graph an 10x10 2D array. The scale should not start at 0 and stop at 9. I want to change these values so 0 corresponds to 0.25 and 9 to 0.75.The values between should be mapped linearly. Using property nodes to change the x-range just seems to change which part of the data is shown on the screen, it does not rescale the x-axis to the new values.
I have done this with the waveform graph. It takes a minimum x value and an x increment and automatically maps the array indexes to the given values. Is there a way to do this with the intensity graph?
Thanks for the help
(4,149 Views)
Accepted by topic author bejurne
Hi bejume,
you can change the offset and multiplier for each scale to reach your goal. In your case  offset=0.25 and multiplier is 0.5/9...
You find these porperties in the formatting dialog or in the property node options (x-scale->offset&multiplier->all elements)!
(4,145 Views)
Thanks, that was exactly what I was looking for.
Kudos!
(4,122 Views)
