the occupational ratio of CPU goes up to 100% when tested
Hey, this is a new learner of Labview8.6 and I had a question about my program. What I did is to pick data from certain lines in a txt file. the function is achieved, but unfortunatelly, the CPU Usage will go directly to 100% after I excuted it. this is not acceptable and is there anyone here had this problems before? and can u give some suggestions?
Cheers
(3,122 Views)
hello,
can you post the piece of code wich poses probleme....
regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,099 Views)
 Using simple while loop???
 try putting some delay. you can achieve this using  "wait (ms)" function.
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,099 Views)
hey, thanks for replying, I got it solven by erasing some useless icons and now it's stable on 20%
(3,054 Views)
