intensity
Did you check out my last screen shot posted? Put the histogram control inside the while loop so that you can see the change when you adjust the image setup.
Message 11 of 21
(2,222 Views)
i see only the first screen shot you posted.. did you post another one?
Message 12 of 21
(2,211 Views)
Message 13 of 21
(2,190 Views)
Muks,
I looked at your block diagram and I am still trying to understand it.  It is still unclear to me how I get the imaq connected to my camera..  do I need to select a certain file path and how?  My camera is img0 but not sure how to hook that up to the imag create etc...
Message 14 of 21
(2,178 Views)
muks,  I am able to get an image with a simple snap vi.  I am now trying to follow your example.. would you mind attaching it vi format so I can follow the wires better and use help to figure out the icons I dont understand.
C
Message 15 of 21
(2,153 Views)
I am still trying to figure out if there is a vi or a system of vi's I can use to get an intensity histogram of an image that I can manipulate.. I have attached a front panel example for further clarity.  unfortunately I dont have access to the block diagram..
Message Edited by calpe3003 on 01-08-2010 02:33 PM
Message 16 of 21
(2,140 Views)
Message Edited by muks on 01-11-2010 08:12 PM
Message 17 of 21
(2,114 Views)
muks... I keep getting an error 1074396154 image is not large enough for the operation...any ideas?
Message 18 of 21
(2,077 Views)
Hi Calpe,
From looking up this error we typically see this when the data types are incompatible. For instance, a customer encountered this error when using a Grayscale (SGL) image where a Grayscale (U8) was necessary.
Some customers have also seen this error when the reference was null (no actual image).
This forum shows a customer who solved this error as well: http://forums.ni.com/ni/board/message?board.id=200&message.id=2008&requireLogin=False
With warm regards,
David D.
Message 19 of 21
(2,051 Views)
I am so horrible at labview...attached is my vi..... can someone help with the error? how do I check image type?
Calpe
Message 20 of 21
(2,027 Views)
