interface .dll - can I involve some C++ code
sure enough not getting the .lib file from the supplier, now its all the hard way
https://learn.microsoft.com/en-us/cpp/build/getprocaddress?view=msvc-170
because visual studio will not compile without the .lib file present. Hope that works, otherwise need a different compiler..
Message 31 of 73
(942 Views)
The compiler is not the problem. All C compilers need an import library lib file when compiling a binary that depends on a DLL. You could change to Linux though, there the ELF format does avoid that when calling into shared libraries.
But the first really working shared library interface for ELF binaries was about 15 years after Microsoft introduced DLLs. So they had some time to avoid a few limitations of DLLs. Shared library support under the various Unixes was in the beginning a crime, they had many inconsistencies, bugs and terrible decisions in the many competing Unix implementations, And Mac had its own thing of course which the obsoleted and redesigned at least two times.
But one of the reason they might not want to provide a lib import file is that that too depends on the C compilers. If they use Visual Studio the resulting lib file that it generates in the COFF format is the defacto standard under Windows and GCC has in the meantime learned to be able to use that as input file, but if they use a GCC based foolchain the resulting binary is often a GCC specific flavor that Visual Studio does not like. It all depends on the actuall GCC flavor used, some customized versions like from MingW by default create fully compatible binaries, stock GCC still needed special handholding with custom command line options to be talked into creating such a format even a few years ago.
There are however tools out there that can generate such import libraries with just the header file and DLL as input. Borland C used to come with one.
Rolf Kalbermatter  My Blog
Message 32 of 73
(937 Views)
if supplier does not even give the .lib file, slim chance they give me anything else. May as well try
Message 33 of 73
(932 Views)
You can easily create lib from any dll in few steps.
1. Run Visual Studio Developer Command Prompt
If you don't know where, then for latest Visual Studio is here:
%comspec% /k "C:\Program Files\Microsoft Visual Studio\2022\Professional\Common7\Tools\VsDevCmd.bat"
2. Execute command
dumpbin /EXPORTS yourfile.dll > yourfile.exports
3. Paste the names of the needed functions from yourfile.exports into a new yourfile.def file. Add a line with the word EXPORTS at the top of this file.
4. Run the following command:
If your DLL is 64-bit:
lib /def:yourfile.def /machine:x64 /out:yourfile.lib
or if 32-bit:
lib /def:yourfile.def /machine:x86 /out:yourfile.lib
I don't remember which bitness is the default or if it depends on the prompt, so it's better to specify explicitly.
In theory you can call lib and dumpbin directly, for latest VS they are here:
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.42.34433\bin\Hostx64\x64
But promt is easier, at least for me.
That is all.
Message 34 of 73
(923 Views)
Message 35 of 73
(908 Views)
Did you read Andrey’s post? All compiler toolchains have a tool to do that in one way or the other. The details are usually buried deep in the documentation as it is an advanced and seldom used feature, but it is there. They can even usually generate a delay-load import library. This import library will only attempt to resolve the imports on the first call of any of those imported functions. Handy if your exe or dll is doing a lot of general stuff and sometimes may need an optional external dll. That way it can be loaded and called even if that other dll is not present on a system. Once you try to call a function from such a DLL it will attempt to load the DLL and on failure prompt you and usually abort your process as that is the only really safe thing to do at this point.
Only challenge is that those tools are generally command line tools. The problem is to specific to warrant creating and especially maintaining in the long run yet another GUI application! But if you seriously want to venture into C programming you definitely shouldn’t be intimidated by a command line! 😀
Message 36 of 73
(901 Views)
I sense trouble here
function names comma separated? enter separated? One wrong letter, it all goes belly up... Anyway, I try both.
Message 37 of 73
(881 Views)
"CRLF" separated
So, let's take lvanlys.dll as an exercise:
dumpbin /EXPORTS "C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2024\lvanlys.dll"  > "%HOMEPATH%\Desktop\lvanlys.exports"
Now I have lvanlys.exports on my desktop with the following content:
Spoiler
Microsoft (R) COFF/PE Dumper Version 14.42.34435.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2024\lvanlys.dll
File Type: DLL
  Section contains the following exports for lvanlys.dll
    00000000 characteristics
    65F16843 time date stamp Wed Mar 13 09:48:03 2024
        0.00 version
           1 ordinal base
         584 number of functions
         584 number of names
    ordinal hint RVA      name
          1    0 00022760 ANOVA3Way_head
          2    1 00022830 ANOVA3Way_head_2017
          3    2 0002DDF0 AllCosWinH
          4    3 0002D710 AllWinH
          5    4 000236D0 Anova1Way_head
          6    5 00023760 Anova1Way_head_2017
          7    6 00022D60 Anova2Way_head
          8    7 00022DE0 Anova2Way_head_2017
          9    8 00020780 AperiodTriangleH
         10    9 00020290 ArbitraryWaveCIN
         11    A 00012D30 AutoCorrMtrxH
         12    B 00026000 AutoCorrelation
         13    C 00026010 AutoCorrelation80
         14    D 00010950 AxBCxAlignedCIN
         15    E 00010930 AxBCxCIN
         16    F 00017120 AxVectAligned_head
         17   10 00017100 AxVect_head
         18   11 000146C0 AxVectorCx
         19   12 000146E0 AxVectorCxAligned
         20   13 00006610 BSplineFit_head
         21   14 0000D7C0 BWCoefs
         22   15 0000D9F0 BWCoefs90
         23   16 000111A0 BandEqsDriH
         24   17 00018D30 BandEqsSetDriH
         25   18 0002D200 BartHannWinH
         26   19 00008A10 BesselCoefs
         27   1A 00008C40 BesselCoefs90
         28   1B 000037E0 BiExpFit_head
         29   1C 00002740 BiGaussFit_head
         30   1D 00003B30 BiLinearFit_head
         31   1E 00008850 BiLogFit_head
         32   1F 00002E10 BiPolyFit_head
         33   20 00006AD0 BiPowerFit_head
         34   21 00021560 BinomialNoiseH
         35   22 0002DD50 BohmanWinH
         36   23 00001CC0 BoundExpFit_head
         37   24 00004C70 BoundGaussianFit_head
         38   25 000035B0 BoundLinearFitBi_head
         39   26 00005F50 BoundLinearFitLAR_head
         40   27 000075A0 BoundLinearFit_head
         41   28 000085C0 BoundLogFit_head
         42   29 000023F0 BoundPowerFit_head
         43   2A 00027C90 CICDecimatorByMovH
         44   2B 00027030 CICInterpolatorByMovH
         45   2C 000014B0 CartesianShift2D_head
         46   2D 000012B0 CartesianShift3D_head
         47   2E 0000A490 ChebyshevCoefs
         48   2F 0000A6D0 ChebyshevCoefs90
         49   30 0001BFC0 CheckPosSemiDef_head
         50   31 0001A2B0 CheckPosdef_head
         51   32 000108E0 CheckSym_head
         52   33 000233E0 ChiSquare_head
         53   34 00020E90 ChirpCIN
         54   35 00028690 ChirpZT_head
         55   36 0001A0C0 CholeskyLinEqs_head
         56   37 000121B0 Cholesky_InvMatrix_head
         57   38 00015890 Cholesky_head
         58   39 00010AE0 CompactToMatrix_H
         59   3A 00013960 Compact_to_Matrix_head
         60   3B 00011E70 CondNumber_head
         61   3C 00005010 ConfBndExp_head
         62   3D 00001F50 ConfBndGauss_head
         63   3E 00007030 ConfBndLinear_head
         64   3F 00007C10 ConfBndLog_head
         65   40 00002A50 ConfBndPoly_head
         66   41 00003160 ConfBndPower_head
         67   42 00022620 Contingency_head
         68   43 00024740 Convolution
         69   44 00026C10 Convolve_2DH
         70   45 000019C0 CoordConversion_head
         71   46 00001620 CoordRotation2D_head
         72   47 00001760 CoordRotationDirect_head
         73   48 00001030 CoordRotationEuler2011_head
         74   49 00001250 CoordRotationEuler_head
         75   4A 000241A0 Correlation_2DH
         76   4B 0002D7D0 CosTapered
         77   4C 0002D830 CosTaperedH
         78   4D 00013EF0 CreateMatrixFromEVs_head
         79   4E 0002B2C0 CrossSpectrumH
         80   4F 0002B3D0 CrossSpectrumH_IDP
         81   50 00006490 CubicSplineFit_head
         82   51 0002DE40 CxAllCosWinH
         83   52 0002D770 CxAllWinH
         84   53 00013AE0 CxAutoCorrMtrxH
         85   54 000127A0 CxBandEqsDriH
         86   55 00019C80 CxBandEqsSetDriH
         87   56 0002D250 CxBartHannWinH
         88   57 0002DDA0 CxBohmanWinH
         89   58 00028BA0 CxCascadedMovingAverageH
         90   59 00018470 CxCheckPosSemiDef_head
         91   5A 00010DB0 CxCheckPosdef_head
         92   5B 00013490 CxCheckSym_head
         93   5C 0002B1A0 CxChirpZT_head
         94   5D 00011C50 CxCholeskyLinEqs_head
         95   5E 00014810 CxCholesky_InvMatrix_head
         96   5F 00019520 CxCholesky_head
         97   60 00016A10 CxCompact_to_Matrix_head
         98   61 0002A960 CxComplexModulatorH
         99   62 00014650 CxCondNumber_head
        100   63 00026330 CxConvolution
        101   64 00025E20 CxConvolve_2DH
        102   65 000261E0 CxCorrelation_2DH
        103   66 0002D880 CxCosTaperedH
        104   67 00028FC0 CxCrossSpectrumH
        105   68 000290B0 CxCrossSpectrumH_IDP
        106   69 0002A200 CxDZTH
        107   6A 0002A350 CxDZTH_IDP
        108   6B 00026950 CxDecimateContinuous_H
        109   6C 00026110 CxDecimate_H
        110   6D 000283E0 CxDecimatedMovingAverageH
        111   6E 00012130 CxDeterminant_head
        112   6F 0002D110 CxDolChebyWinH
        113   70 00012A90 CxEigenVBack_head
        114   71 00013D80 CxEigenValueVector_head
        115   72 00014210 CxEqsByCholeskyDri_head
        116   73 0001B2A0 CxEqsByLUDri_head
        117   74 00010E20 CxEqsSetByCholeskyDri_head
        118   75 00018EF0 CxEqsSetByLUDri_head
        119   76 0001ADB0 CxEqsSetBySVDDri82_head
        120   77 0001AC90 CxEqsSetBySVDDri_head
        121   78 0002D980 CxExpWinH
        122   79 00029BE0 CxFFT2D_H
        123   7A 00029D90 CxFFT2D_H_IDP
        124   7B 0002D410 CxForceWinH
        125   7C 000154E0 CxFullCholesky_head
        126   7D 0001B730 CxGSVD_head
        127   7E 0002DAE0 CxGaussWinH
        128   7F 0002DBD0 CxGenCosWinH
        129   80 00016CB0 CxGenEigenEx_head
        130   81 0001B5B0 CxGenLinEqs82_head
        131   82 0001B440 CxGenLinEqs_head
        132   83 00018DD0 CxHessenberg_head
        133   84 0000DC70 CxIIRReSig_Filter_H
        134   85 00008EC0 CxIIR_Filter_H
        135   86 00014970 CxInitialMatrixH
        136   87 00028420 CxInvFFT2D_H
        137   88 00028540 CxInvFFT2D_H_IDP
        138   89 00017600 CxInvMatrixChoDri_head
        139   8A 000105A0 CxInvMatrixLUDri_head
        140   8B 00015440 CxInvMatrixTriDri_head
        141   8C 0002D510 CxKaiserH
        142   8D 00016FD0 CxKroneckerProd_H
        143   8E 0001A010 CxLUInvMatrix_head
        144   8F 00017C40 CxLULinEqs_head
        145   90 00019250 CxLU_head
        146   91 00012FF0 CxLyapunov85_head
        147   92 00012FD0 CxLyapunov_head
        148   93 00019400 CxMatrixBalance_head
        149   94 00015610 CxMatrixCharacteristicPoly_head
        150   95 00012710 CxMatrixExp_head
        151   96 000183E0 CxMatrixLn_head
        152   97 00012410 CxMatrixPower_head
        153   98 00014550 CxMatrixSqrt_head
        154   99 00014A60 CxMatrix_to_Compact_head
        155   9A 0001C760 CxMultPolyRoots_head
        156   9B 0001C9F0 CxMultiplyPolyH
        157   9C 000292E0 CxNIFFTH
        158   9D 00029310 CxNIFFTH80
        159   9E 000295D0 CxNIFFTH80_IDP
        160   9F 0001B3D0 CxNorm_head
        161   A0 0002DB80 CxParzenWinH
        162   A1 0001CD90 CxPolyGCD_H
        163   A2 0001DA30 CxPolyRoots_head
        164   A3 00017890 CxPseudoInverse_head
        165   A4 0001C440 CxQRDecH
        166   A5 00018970 CxQZ80_head
        167   A6 00018940 CxQZ_head
        168   A7 00022680 CxRMS_head
        169   A8 000144F0 CxRank_head
        170   A9 000242F0 CxRationalResampleMCh_H
        171   AA 00026DF0 CxRationalResample_H
        172   AB 000279A0 CxResample_Const
        173   AC 00024B10 CxResample_Variable
        174   AD 00024C50 CxResample_Variable_MultiCh
        175   AE 0001B0A0 CxSVDEx_head
        176   AF 0001A1C0 CxSVDS_head
        177   B0 0001BBE0 CxSVD_head
        178   B1 0002D300 CxScaledWinH
        179   B2 0001AA50 CxSchur80_head
        180   B3 00011A30 CxSchur_head
        181   B4 0000C370 CxSigFIRnarrowFilter_head
        182   B5 0000CE10 CxSigIIR_Filter
        183   B6 0000E210 CxSigIIR_Filter2
        184   B7 0000D1A0 CxSigIIR_Filter_OneState
        185   B8 0000D420 CxSigIIR_Filter_PtbyPt
        186   B9 00017940 CxSpecialMatrix_head
        187   BA 0002AFF0 CxSpectrumH
        188   BB 0002B0B0 CxSpectrumH_IDP
        189   BC 000143C0 CxSylvester81_head
        190   BD 00014370 CxSylvester_head
        191   BE 0002DA30 CxSymmWinH
        192   BF 0001C010 CxTmiQZ_head
        193   C0 00012280 CxTrace_head
        194   C1 00019B70 CxTranspose_head
        195   C2 000184C0 CxTriEqsSetDri_head
        196   C3 000195F0 CxTriLinEqs_head
        197   C4 00018860 CxTri_InvMatrix_head
        198   C5 0002D6C0 CxTriangleWinH
        199   C6 0001DC20 CxUnitVector80_head
        200   C7 0001DBA0 CxUnitVector_head
        201   C8 00010880 CxVectorNormH
        202   C9 000122F0 CxVectxAAligned_head
        203   CA 000122E0 CxVectxA_head
        204   CB 0002D1B0 CxWelchWinH
        205   CC 00011220 Cxqrd_head
        206   CD 0001E6F0 CycleRMSAverage
        207   CE 0001E900 CycleRMSAverage_IDP
        208   CF 00029F50 DCT_1DH
        209   D0 0002A090 DCT_1DH_IDP
        210   D1 0002B4F0 DCT_2DH
        211   D2 0002B6B0 DCT_2DH_IDP
        212   D3 000287B0 DST_1DH
        213   D4 000288D0 DST_1DH_IDP
        214   D5 0002A4B0 DST_2DH
        215   D6 0002A670 DST_2DH_IDP
        216   D7 00025D30 DecimateCIN
        217   D8 00025540 DecimateContinuous_H
        218   D9 00026460 DecimatorFIRH
        219   DA 00026650 Deconvolution
        220   DB 00025B90 Derivative
        221   DC 00025C30 Derivative85
        222   DD 00013600 Determinant_head
        223   DE 00001960 Direction2Euler2011_head
        224   DF 00001980 Direction2Euler_head
        225   E0 0002E1A0 DisableAnalysisWorkspaceH
        226   E1 0002D0C0 DolChebyWinH
        227   E2 00019FA0 DotProduct_head
        228   E3 00018C20 DotprodCx
        229   E4 000157D0 EigenVBack_head
        230   E5 00014B90 EigenValueVector_head
        231   E6 00009F80 EllipticCoefs
        232   E7 0000A1F0 EllipticCoefs90
        233   E8 0002E1A0 EnableAnalysisWorkspaceH
        234   E9 00012820 EqsByCholeskyDri_head
        235   EA 000168E0 EqsByLUDri_head
        236   EB 00018650 EqsSetByCholeskyDri_head
        237   EC 00011D50 EqsSetByLUDri_head
        238   ED 00010460 EqsSetBySVDDri82_head
        239   EE 00010340 EqsSetBySVDDri_head
        240   EF 00001BB0 Euler2Direction2011_head
        241   F0 00001CA0 Euler2Direction_head
        242   F1 0001DE20 EvPoly2D
        243   F2 00005470 ExpFit80_head
        244   F3 00007860 ExpFitCoef80_head
        245   F4 000077B0 ExpFitCoef_head
        246   F5 000052C0 ExpFit_head
        247   F6 0002D930 ExpWinH
        248   F7 0002D8D0 ExpWindCIN
        249   F8 00023A00 FDist_head
        250   F9 0002CF90 FHTH
        251   FA 0002D010 FHTH_IDP
        252   FB 0000FA00 FIRCoefs
        253   FC 00009250 FIRNarrowCoef_head
        254   FD 0000E490 FIRnarrowFilter_head
        255   FE 000291B0 FastHilbertTransformH
        256   FF 00029230 FastHilbertTransformH_IDP
        257  100 0002D3C0 ForceWinH
        258  101 0002D360 ForceWindCIN
        259  102 0002E040 FreqMod
        260  103 00017260 FullCholesky_head
        261  104 00017CF0 GSVD_head
        262  105 000211D0 GammaNoiseH
        263  106 000218F0 Gauss
        264  107 00020B40 GaussMonopulseH
        265  108 000209D0 GaussPulseH
        266  109 0002DA90 GaussWinH
        267  10A 00007470 GaussianPeakFitCoef_head
        268  10B 00006970 GaussianPeakFit_head
        269  10C 00005CC0 GenBisquareFit_Weight_head
        270  10D 00005A20 GenBisquareFit_head
        271  10E 0002DC90 GenCosWinH
        272  10F 00016550 GenEigenEx_head
        273  110 00023A50 GenHistH
        274  111 00004260 GenLARFit_head
        275  112 00008360 GenLSFit80_head
        276  113 00008030 GenLSFit_head
        277  114 0001A610 GenLinEqs2010_head
        278  115 0001A490 GenLinEqs82_head
        279  116 0001A320 GenLinEqs_head
        280  117 0001A820 GenLinEqsbySVD2011_head
        281  118 00004F10 GetNewCoef_head
        282  119 00002680 GoodnessOfFit_head
        283  11A 000174E0 Hessenberg_head
        284  11B 0000B0E0 IIR_Filter
        285  11C 0000DF90 IIR_Filter2
        286  11D 0000B460 IIR_Filter_OneState
        287  11E 0000B6C0 IIR_Filter_PtbyPt
        288  11F 00020500 ImpulsePtrn
        289  120 000156E0 InitialMatrixH
        290  121 0002E170 InitializeAnalysisWorkspaceH
        291  122 000256A0 Integral
        292  123 00025740 Integral90
        293  124 00025870 Integral_2017
        294  125 000245D0 InterpolatedFIRH
        295  126 000258E0 InterpolatorFIRH
        296  127 0000FB40 InvChebyshevCoefs
        297  128 0000FD80 InvChebyshevCoefs90
        298  129 00023240 InvChiSquare_head
        299  12A 0002BBE0 InvChirpZT_head
        300  12B 000298A0 InvCxNIFFTH
        301  12C 000298B0 InvCxNIFFTH80
        302  12D 00029A30 InvCxNIFFTH80_IDP
        303  12E 0002ADA0 InvDCT_1DH
        304  12F 0002AEB0 InvDCT_1DH_IDP
        305  130 00027FE0 InvDCT_2DH
        306  131 00028110 InvDCT_2DH_IDP
        307  132 0002B980 InvDST_1DH
        308  133 0002BAA0 InvDST_1DH_IDP
        309  134 0002CAB0 InvDST_2DH
        310  135 0002CBD0 InvDST_2DH_IDP
        311  136 00023290 InvFDist_head
        312  137 0002A840 InvFHTH
        313  138 0002A8B0 InvFHTH_IDP
        314  139 00028270 InvFastHilbertTransformH
        315  13A 000282F0 InvFastHilbertTransformH_IDP
        316  13B 000148E0 InvMatrixChoDri_head
        317  13C 00014000 InvMatrixLUDri_head
        318  13D 00018C90 InvMatrixTriDri_head
        319  13E 000239C0 InvNdist_head
        320  13F 0002C500 InvReNIFFTH
        321  140 0002C510 InvReNIFFTH80
        322  141 0002C650 InvReNIFFTH80_IDP
        323  142 0002C7B0 InvReNIFFTHCH
        324  143 0002C880 InvReNIFFTHCH_IDP
        325  144 00023970 InvTdist_head
        326  145 0002D4C0 KaiserH
        327  146 0002D460 Kaiser_Bessel
        328  147 00015310 KroneckerProd_H
        329  148 000072E0 LARExpFit_head
        330  149 00007990 LARGaussFit_head
        331  14A 00002CE0 LARLinearFit_head
        332  14B 00006C40 LARLogFit_head
        333  14C 00006D90 LARPolyFit_head
        334  14D 00006800 LARPowerFit_head
        335  14E 00019010 LUInvMatrix_head
        336  14F 00019710 LULinEqs_head
        337  150 000130F0 LU_head
        338  151 00021E30 LV_Airy
        339  152 00021EC0 LV_BesselIr
        340  153 00021E40 LV_BesselJr
        341  154 00021E80 LV_BesselJs
        342  155 00021EE0 LV_BesselKn
        343  156 00021E60 LV_BesselYr
        344  157 00021EA0 LV_BesselYs
        345  158 00021F00 LV_Beta
        346  159 00021F60 LV_Beta_85
        347  15A 00022360 LV_CosI
        348  15B 000223A0 LV_CoshI
        349  15C 000225F0 LV_CxAiry
        350  15D 00022570 LV_CxBesselHr
        351  15E 000225D0 LV_CxBesselHs
        352  15F 000225A0 LV_CxBesselIr
        353  160 00022550 LV_CxBesselJr
        354  161 000225B0 LV_CxBesselJs
        355  162 00022590 LV_CxBesselKr
        356  163 00022560 LV_CxBesselYr
        357  164 000225C0 LV_CxBesselYs
        358  165 00022310 LV_Dawson
        359  166 000224B0 LV_Diln
        360  167 000221B0 LV_Elliptic1
        361  168 00022200 LV_Elliptic1_85
        362  169 00022240 LV_Elliptic2
        363  16A 00022290 LV_Elliptic2_85
        364  16B 000223E0 LV_EllipticJ
        365  16C 000222D0 LV_Erf
        366  16D 000222F0 LV_ErfC
        367  16E 00022340 LV_ExpI
        368  16F 00021F90 LV_Fact
        369  170 00022330 LV_FresnelIntegrals
        370  171 00021FB0 LV_Gamma
        371  172 00022030 LV_GammaC
        372  173 00022000 LV_Gamma_85
        373  174 00022110 LV_Gauss
        374  175 000220D0 LV_Gauss_2011
        375  176 00022410 LV_KelvinI
        376  177 00022460 LV_KelvinK
        377  178 00022150 LV_Kummer
        378  179 00022050 LV_LnFact
        379  17A 00022070 LV_LnGamma
        380  17B 000224D0 LV_ParabolicCylinder
        381  17C 00022090 LV_Psi
        382  17D 00022380 LV_SinI
        383  17E 000223C0 LV_SinhI
        384  17F 000220B0 LV_Stirling
        385  180 00022500 LV_Struve
        386  181 00022180 LV_Tricomi
        387  182 00022530 LV_Zeta
        388  183 0001D6E0 LinEv
        389  184 00006220 LinFitCoef80_head
        390  185 00006190 LinFitCoef_head
        391  186 00005610 LinFit_head
        392  187 0001D5E0 Line1
        393  188 00002230 LogFitCoef_head
        394  189 00007B10 LogFit_head
        395  18A 00012990 Lyapunov85_head
        396  18B 00012970 Lyapunov_head
        397  18C 00023330 MSE_head
        398  18D 00017B20 MatrixBalance_head
        399  18E 000132A0 MatrixCharacteristicPoly_head
        400  18F 00012680 MatrixExp_head
        401  190 000133A0 MatrixLn_head
        402  191 0001AF10 MatrixMulAligned_head
        403  192 0001AEF0 MatrixMul_head
        404  193 00018780 MatrixPower_head
        405  194 00019D20 MatrixSqrtH
        406  195 00019DF0 MatrixSqrt_head
        407  196 00011F50 MatrixToCompact_H
        408  197 00017390 Matrix_to_Compact_head
        409  198 00023910 Mean_head
        410  199 0001F5F0 MeasurementUnreserveProc
        411  19A 0000CDB0 MedianFilter81_H
        412  19B 0000CD50 MedianFilterCIN
        413  19C 000226B0 Median_head
        414  19D 00023600 ModeH
        415  19E 00023390 Moment_head
        416  19F 0001DF30 MultPolyRoots_head
        417  1A0 0001FA30 MultipleToneMeasurements
        418  1A1 0001D3C0 MultiplyPolyH
        419  1A2 0001DAE0 Norm1
        420  1A3 0001D830 Norm2
        421  1A4 00023900 NormDist_head
        422  1A5 000145E0 Norm_head
        423  1A6 0002DE90 NumWinConstH
        424  1A7 0001DD60 NumerIntegration2D_2017_head
        425  1A8 0001DCA0 NumerIntegration2D_head
        426  1A9 0001D530 NumerIntegration3D_2017_head
        427  1AA 0001D480 NumerIntegration3D_head
        428  1AB 0001D230 NumerIntegration_2017_head
        429  1AC 0001D1B0 NumerIntegration_head
        430  1AD 0001BE90 OuterProdCx_head
        431  1AE 000167B0 OuterProd_head
        432  1AF 00009520 Parks
        433  1B0 0002DB30 ParzenWinH
        434  1B1 0001E330 PeakD
        435  1B2 0001E360 PeakD2010
        436  1B3 0001E390 PeakD2014
        437  1B4 0001E1C0 PeakDetector
        438  1B5 00021C20 PeriodNoise
        439  1B6 00021D30 PeriodicSincH
        440  1B7 0002DED0 PhasMod
        441  1B8 00021310 PoissonNoiseH
        442  1B9 0001D780 PolarToRect1D_head
        443  1BA 0001D340 PolyEv
        444  1BB 00003E00 PolyFit80_head
        445  1BC 00004020 PolyFit81_head
        446  1BD 00003C40 PolyFit_head
        447  1BE 0001CAB0 PolyGCD_H
        448  1BF 00008990 PolyInterp_head
        449  1C0 0001D8D0 PolyRootsNtBst_head
        450  1C1 000022E0 PowerFitCoef_head
        451  1C2 000056E0 PowerFit_head
        452  1C3 00015960 PreallocInvMatrixChoDri_H
        453  1C4 00004840 PredBndExp_head
        454  1C5 00005870 PredBndGauss_head
        455  1C6 00003410 PredBndLinear_head
        456  1C7 00003970 PredBndLog_head
        457  1C8 000028C0 PredBndPoly_head
        458  1C9 000062F0 PredBndPower_head
        459  1CA 00014090 PseudoInverse_head
        460  1CB 0001ED50 PulseMeas
        461  1CC 0001EAE0 PulseMeasEx
        462  1CD 0001EE00 PulseMeasEx_IDP
        463  1CE 00025A70 PulseParameters
        464  1CF 00020180 PulsePtrn
        465  1D0 00011710 QRDecH
        466  1D1 0001D660 QS1D
        467  1D2 0001DEA0 QScale
        468  1D3 000136B0 QZ80_head
        469  1D4 00013680 QZ_head
        470  1D5 000232E0 RMS_head
        471  1D6 00020FB0 RampPtrn
        472  1D7 000210A0 RampPtrn80
        473  1D8 000210C0 RampPtrn85
        474  1D9 00011EE0 Rank_head
        475  1DA 00006590 RatInterp_head
        476  1DB 000273C0 RationalResampleMultiCh_H
        477  1DC 00026710 RationalResample_H
        478  1DD 00028A30 ReCascadedMovingAverageH
        479  1DE 0002A990 ReComplexModulatorH
        480  1DF 00028D10 ReDZTH
        481  1E0 00028E60 ReDZTH_IDP
        482  1E1 000283A0 ReDecimatedMovingAverageH
        483  1E2 0002AA30 ReFFT2D_H
        484  1E3 0002ABE0 ReFFT2D_H_IDP
        485  1E4 0002CD20 ReInvFFT2D_H
        486  1E5 0002CE40 ReInvFFT2D_H_IDP
        487  1E6 0002BEE0 ReNIFFTH
        488  1E7 0002BF10 ReNIFFTH80
        489  1E8 0002C100 ReNIFFTH80_IDP
        490  1E9 0002C330 ReNIFFTHCH
        491  1EA 0002C400 ReNIFFTHCH_IDP
        492  1EB 0001D290 RectToPolar1D_head
        493  1EC 000276A0 Resample_Const
        494  1ED 00024870 Resample_Variable
        495  1EE 00024910 Resample_Variable_MultiCh
        496  1EF 00020090 RiffleArrayCDB2012_head
        497  1F0 00020070 RiffleArrayCDB_head
        498  1F1 00021B30 RiffleArrayDBL2012_head
        499  1F2 00021B10 RiffleArrayDBL_head
        500  1F3 00020C80 RiffleArrayInt2012_head
        501  1F4 00020C60 RiffleArrayInt_head
        502  1F5 00021A50 RiffleIntNum2012_head
        503  1F6 00021A30 RiffleIntNum_head
        504  1F7 000049E0 RmvOutlierIndx_head
        505  1F8 000044F0 RmvOutlierRng_head
        506  1F9 00026AA0 Rxy
        507  1FA 00026AC0 Rxy80
        508  1FB 00017690 SVDEx_head
        509  1FC 00015220 SVDS_head
        510  1FD 00010F50 SVD_head
        511  1FE 00009E00 SavitzkyGolayCoefH
        512  1FF 00010010 SavitzkyGolayFiltH
        513  200 0001FF60 SawtoothWaveCIN
        514  201 0001D110 Scale
        515  202 0001CD00 Scale1DCIN
        516  203 0002DC30 ScaledCxGenCosWinH
        517  204 0002DCF0 ScaledGenCosWinH
        518  205 0002D2A0 ScaledWinH
        519  206 000181A0 Schur80_head
        520  207 00010120 Schur_head
        521  208 00141D70 SetLVRTModule
        522  209 00141DA0 SetLVRTModuleHook
        523  20A 00141D80 SetLVRTTLSIndex
        524  20B 00141DA0 SetLVRTTLSIndexHook
        525  20C 000208B0 SincWave
        526  20D 000216C0 SinePtrn
        527  20E 000217E0 SineWaveCIN
        528  20F 000030B0 SpInterp_head
        529  210 00012B50 SpecialMatrix_head
        530  211 0002C980 SpectrumH
        531  212 0002CA00 SpectrumH_IDP
        532  213 00007EE0 Spline_head
        533  214 00020610 Square
        534  215 00020D70 SquareWaveCIN
        535  216 0001F7B0 StateLevels
        536  217 0001F900 StateLevels_IDP
        537  218 00016420 Sylvester81_head
        538  219 000163D0 Sylvester_head
        539  21A 00011540 SymEvectorEvalue_head
        540  21B 0002D9D0 SymmWinH
        541  21C 00022710 TDist_head
        542  21D 00014D50 TmiQZ_head
        543  21E 000190C0 Trace_head
        544  21F 0001F040 TransMeas
        545  220 0001F330 TransMeas_IDP
        546  221 0002BCF0 TransformUnreserveProc
        547  222 00014140 Transpose_head
        548  223 00019A70 TriDiagEqsByLU_head
        549  224 00016B90 TriDiagEqsSetByLU_head
        550  225 00019870 TriDiagLU_head
        551  226 000124F0 TriEqsSetDri_head
        552  227 000134F0 TriLinEqs_head
        553  228 00011460 Tri_InvMatrix_head
        554  229 00021450 TriangleWaveCIN
        555  22A 0002D610 TriangleWin
        556  22B 0002D670 TriangleWinH
        557  22C 00024E50 Triggerh
        558  22D 00023CE0 Triggerh_86
        559  22E 0002E1A0 UninitializeAnalysisWorkspaceH
        560  22F 0002D160 WelchWinH
        561  230 0002D5D0 WinConstByNameH
        562  231 0002D560 WinConstByNameH_2016
        563  232 000CA120 create_nifft_table
        564  233 000CA160 destroy_nifft_table
        565  234 00023430 histgran_head
        566  235 0001FF50 measurements_clear
        567  236 0001FF50 measurements_create
        568  237 0001FF50 measurements_destroy
        569  238 0001FD50 measurements_fetch
        570  239 0000F540 ppMultiRateFIRH_CDB
        571  23A 0000F7A0 ppMultiRateFIRH_CSG
        572  23B 0000F080 ppMultiRateFIRH_DBL
        573  23C 0000F2E0 ppMultiRateFIRH_SGL
        574  23D 00010630 qrd_head
        575  23E 00025460 unWrap
        576  23F 000254E0 unWrap85
        577  240 0001D080 unitVector80_head
        578  241 0001CFE0 unitVector_head
        579  242 00019A10 vectorNormH
        580  243 00019130 vectxAAligned_head
        581  244 00019120 vectxA_head
        582  245 000203D0 white
        583  246 0000CB60 zeroPhaseCascadeFiltH
        584  247 0000C790 zeroPhaseFiltH
  Summary
        6000 .data
        1000 .gfids
        E000 .pdata
       33000 .rdata
        1000 .reloc
        1000 .rsrc
      155000 .text
        5000 _RDATA
Now I will copy *-exports to *.def, keep all names and add EXPORTS as first line:
Spoiler
EXPORTS
ANOVA3Way_head
ANOVA3Way_head_2017
AllCosWinH
AllWinH
Anova1Way_head
Anova1Way_head_2017
Anova2Way_head
Anova2Way_head_2017
AperiodTriangleH
ArbitraryWaveCIN
AutoCorrMtrxH
AutoCorrelation
AutoCorrelation80
AxBCxAlignedCIN
AxBCxCIN
AxVectAligned_head
AxVect_head
AxVectorCx
AxVectorCxAligned
BSplineFit_head
BWCoefs
BWCoefs90
BandEqsDriH
BandEqsSetDriH
BartHannWinH
BesselCoefs
BesselCoefs90
BiExpFit_head
BiGaussFit_head
BiLinearFit_head
BiLogFit_head
BiPolyFit_head
BiPowerFit_head
BinomialNoiseH
BohmanWinH
BoundExpFit_head
BoundLinearFit_head
BoundLogFit_head
BoundPowerFit_head
CICDecimatorByMovH
ChebyshevCoefs
ChebyshevCoefs90
CheckPosdef_head
CheckSym_head
ChiSquare_head
ChirpCIN
ChirpZT_head
CholeskyLinEqs_head
Cholesky_head
CompactToMatrix_H
CondNumber_head
ConfBndExp_head
ConfBndGauss_head
ConfBndLinear_head
ConfBndLog_head
ConfBndPoly_head
ConfBndPower_head
Contingency_head
Convolution
Convolve_2DH
Correlation_2DH
CosTapered
CosTaperedH
CrossSpectrumH
CrossSpectrumH_IDP
CubicSplineFit_head
CxAllCosWinH
CxAllWinH
CxAutoCorrMtrxH
CxBandEqsDriH
CxBandEqsSetDriH
CxBartHannWinH
CxBohmanWinH
CxCheckPosdef_head
CxCheckSym_head
CxChirpZT_head
CxCholesky_head
CxComplexModulatorH
CxCondNumber_head
CxConvolution
CxConvolve_2DH
CxCorrelation_2DH
CxCosTaperedH
CxCrossSpectrumH
CxDZTH
CxDZTH_IDP
CxDecimate_H
CxDeterminant_head
CxDolChebyWinH
CxEigenVBack_head
CxEqsByLUDri_head
CxExpWinH
CxFFT2D_H
CxFFT2D_H_IDP
CxForceWinH
CxFullCholesky_head
CxGSVD_head
CxGaussWinH
CxGenCosWinH
CxGenEigenEx_head
CxGenLinEqs82_head
CxGenLinEqs_head
CxHessenberg_head
CxIIRReSig_Filter_H
CxIIR_Filter_H
CxInitialMatrixH
CxInvFFT2D_H
CxInvFFT2D_H_IDP
CxKaiserH
CxKroneckerProd_H
CxLUInvMatrix_head
CxLULinEqs_head
CxLU_head
CxLyapunov85_head
CxLyapunov_head
CxMatrixExp_head
CxMatrixLn_head
CxMatrixPower_head
CxMatrixSqrt_head
CxMultiplyPolyH
CxNIFFTH
CxNIFFTH80
CxNIFFTH80_IDP
CxNorm_head
CxParzenWinH
CxPolyGCD_H
CxPolyRoots_head
CxQRDecH
CxQZ80_head
CxQZ_head
CxRMS_head
CxRank_head
CxResample_Const
CxResample_Variable
CxSVDEx_head
CxSVDS_head
CxSVD_head
CxScaledWinH
CxSchur80_head
CxSchur_head
CxSigIIR_Filter
CxSigIIR_Filter2
CxSpectrumH
CxSpectrumH_IDP
CxSylvester81_head
CxSylvester_head
CxSymmWinH
CxTmiQZ_head
CxTrace_head
CxTranspose_head
CxTriEqsSetDri_head
CxTriLinEqs_head
CxTriangleWinH
CxUnitVector80_head
CxUnitVector_head
CxVectorNormH
CxVectxA_head
CxWelchWinH
Cxqrd_head
CycleRMSAverage
CycleRMSAverage_IDP
DCT_1DH
DCT_1DH_IDP
DCT_2DH
DCT_2DH_IDP
DST_1DH
DST_1DH_IDP
DST_2DH
DST_2DH_IDP
DecimateCIN
DecimatorFIRH
Deconvolution
Derivative
Derivative85
Determinant_head
DolChebyWinH
DotProduct_head
DotprodCx
EigenVBack_head
EllipticCoefs
EllipticCoefs90
EqsByLUDri_head
EqsSetByLUDri_head
EqsSetBySVDDri_head
EvPoly2D
ExpFit80_head
ExpFitCoef80_head
ExpFitCoef_head
ExpFit_head
ExpWinH
ExpWindCIN
FDist_head
FHTH
FHTH_IDP
FIRCoefs
FIRNarrowCoef_head
ForceWinH
ForceWindCIN
FreqMod
FullCholesky_head
GSVD_head
GammaNoiseH
Gauss
GaussMonopulseH
GaussPulseH
GaussWinH
GenBisquareFit_head
GenCosWinH
GenEigenEx_head
GenHistH
GenLARFit_head
GenLSFit80_head
GenLSFit_head
GenLinEqs2010_head
GenLinEqs82_head
GenLinEqs_head
GetNewCoef_head
GoodnessOfFit_head
Hessenberg_head
IIR_Filter
IIR_Filter2
IIR_Filter_OneState
IIR_Filter_PtbyPt
ImpulsePtrn
InitialMatrixH
Integral
Integral90
Integral_2017
InterpolatedFIRH
InterpolatorFIRH
InvChebyshevCoefs
InvChebyshevCoefs90
InvChiSquare_head
InvChirpZT_head
InvCxNIFFTH
InvCxNIFFTH80
InvCxNIFFTH80_IDP
InvDCT_1DH
InvDCT_1DH_IDP
InvDCT_2DH
InvDCT_2DH_IDP
InvDST_1DH
InvDST_1DH_IDP
InvDST_2DH
InvDST_2DH_IDP
InvFDist_head
InvFHTH
InvFHTH_IDP
InvMatrixLUDri_head
InvNdist_head
InvReNIFFTH
InvReNIFFTH80
InvReNIFFTH80_IDP
InvReNIFFTHCH
InvReNIFFTHCH_IDP
InvTdist_head
KaiserH
Kaiser_Bessel
KroneckerProd_H
LARExpFit_head
LARGaussFit_head
LARLinearFit_head
LARLogFit_head
LARPolyFit_head
LARPowerFit_head
LUInvMatrix_head
LULinEqs_head
LU_head
LV_Airy
LV_BesselIr
LV_BesselJr
LV_BesselJs
LV_BesselKn
LV_BesselYr
LV_BesselYs
LV_Beta
LV_Beta_85
LV_CosI
LV_CoshI
LV_CxAiry
LV_CxBesselHr
LV_CxBesselHs
LV_CxBesselIr
LV_CxBesselJr
LV_CxBesselJs
LV_CxBesselKr
LV_CxBesselYr
LV_CxBesselYs
LV_Dawson
LV_Diln
LV_Elliptic1
LV_Elliptic1_85
LV_Elliptic2
LV_Elliptic2_85
LV_EllipticJ
LV_Erf
LV_ErfC
LV_ExpI
LV_Fact
LV_FresnelIntegrals
LV_Gamma
LV_GammaC
LV_Gamma_85
LV_Gauss
LV_Gauss_2011
LV_KelvinI
LV_KelvinK
LV_Kummer
LV_LnFact
LV_LnGamma
LV_Psi
LV_SinI
LV_SinhI
LV_Stirling
LV_Struve
LV_Tricomi
LV_Zeta
LinEv
LinFitCoef80_head
LinFitCoef_head
LinFit_head
Line1
LogFitCoef_head
LogFit_head
Lyapunov85_head
Lyapunov_head
MSE_head
MatrixBalance_head
MatrixExp_head
MatrixLn_head
MatrixMul_head
MatrixPower_head
MatrixSqrtH
MatrixSqrt_head
MatrixToCompact_H
Mean_head
MedianFilter81_H
MedianFilterCIN
Median_head
ModeH
Moment_head
MultPolyRoots_head
MultiplyPolyH
Norm1
Norm2
NormDist_head
Norm_head
NumWinConstH
OuterProdCx_head
OuterProd_head
Parks
ParzenWinH
PeakD
PeakD2010
PeakD2014
PeakDetector
PeriodNoise
PeriodicSincH
PhasMod
PoissonNoiseH
PolarToRect1D_head
PolyEv
PolyFit80_head
PolyFit81_head
PolyFit_head
PolyGCD_H
PolyInterp_head
PolyRootsNtBst_head
PowerFitCoef_head
PowerFit_head
PredBndExp_head
PredBndGauss_head
PredBndLinear_head
PredBndLog_head
PredBndPoly_head
PredBndPower_head
PseudoInverse_head
PulseMeas
PulseMeasEx
PulseMeasEx_IDP
PulseParameters
PulsePtrn
QRDecH
QS1D
QScale
QZ80_head
QZ_head
RMS_head
RampPtrn
RampPtrn80
RampPtrn85
Rank_head
RatInterp_head
RationalResample_H
ReComplexModulatorH
ReDZTH
ReDZTH_IDP
ReFFT2D_H
ReFFT2D_H_IDP
ReInvFFT2D_H
ReInvFFT2D_H_IDP
ReNIFFTH
ReNIFFTH80
ReNIFFTH80_IDP
ReNIFFTHCH
ReNIFFTHCH_IDP
RectToPolar1D_head
Resample_Const
Resample_Variable
RiffleArrayCDB_head
RiffleArrayDBL_head
RiffleArrayInt_head
RiffleIntNum_head
RmvOutlierIndx_head
RmvOutlierRng_head
Rxy
Rxy80
SVDEx_head
SVDS_head
SVD_head
SavitzkyGolayCoefH
SavitzkyGolayFiltH
SawtoothWaveCIN
Scale
Scale1DCIN
ScaledCxGenCosWinH
ScaledGenCosWinH
ScaledWinH
Schur80_head
Schur_head
SetLVRTModule
SetLVRTModuleHook
SetLVRTTLSIndex
SetLVRTTLSIndexHook
SincWave
SinePtrn
SineWaveCIN
SpInterp_head
SpecialMatrix_head
SpectrumH
SpectrumH_IDP
Spline_head
Square
SquareWaveCIN
StateLevels
StateLevels_IDP
Sylvester81_head
Sylvester_head
SymmWinH
TDist_head
TmiQZ_head
Trace_head
TransMeas
TransMeas_IDP
Transpose_head
TriDiagEqsByLU_head
TriDiagLU_head
TriEqsSetDri_head
TriLinEqs_head
Tri_InvMatrix_head
TriangleWaveCIN
TriangleWin
TriangleWinH
Triggerh
Triggerh_86
WelchWinH
WinConstByNameH
create_nifft_table
destroy_nifft_table
histgran_head
measurements_clear
measurements_create
measurements_fetch
ppMultiRateFIRH_CDB
ppMultiRateFIRH_CSG
ppMultiRateFIRH_DBL
ppMultiRateFIRH_SGL
qrd_head
unWrap
unWrap85
unitVector80_head
unitVector_head
vectorNormH
vectxAAligned_head
vectxA_head
white
zeroPhaseFiltH
And finally
lib /def:"%HOMEPATH%\Desktop\lvanlys.def" /machine:x64 /out:"%HOMEPATH%\Desktop\lvanlys.lib"
Of course, I will not type every name manually. Just use any editor that can select a column, such as VSCode, and then select everything you don't need by holding down the Ctrl, Shift, and Alt keys alltogether.
Message 38 of 73
(871 Views)
so its essentially the same as in post 4, results of dependency walker?
Message 39 of 73
(866 Views)
Yes, it is. Exports are exports. The Dependencies Walker is always in my "hacker's toolbox." By the way, you're using a "legacy" tool, which may have some issues on modern operating systems (for example, it can be very slow). I using a slightly different Dependencies Tool, but the result is generally the same.
Its could be a little bit more complicated to get correct lib in case of decorated/mangled function's names, but impossible is nothing.
Message 40 of 73
(854 Views)
