interfacing muliple Adxl 345 (accelometers) on Labview
Hello , Im trying to interface multiple Accelometers (Adxl 345) using Arduino uno and Labview with LabVIEW Interface for Arduino and LINX
when im trying to connect only one Accelometer it works fine , but how can i connect multiple accelomters as there is only one working address (0x53) , (0x1D) is not working
(1,205 Views)
Try using the addresses in decimal format: 83 for 0x53 and 29 for 0x1D.
You may find this useful: https://www.instructables.com/Simple-Accelerometer-In-labVIEW/
If you can not measure it, you can not improve it.
- Lord Kelvin
(1,171 Views)
When you connected to two ADXL 345, did you set both to different addresses by connecting one ALT to HIGH and the other ALT to LOW?
Santhosh
Soliton Technologies
(1,169 Views)
