interfacing of hardware with labview
Earlier you said you had a controller and driver for the stepper. Now you are saying you don't?
Have you tried any simple searches of the forum. A quick one of "PWM 6008' turned up this.
Message 31 of 55
(1,937 Views)
               contoller is the usb NI 6009....... i have a driver also ....... can u pls tell me what mistake i  have done.......
Message 32 of 55
(1,920 Views)
So if I now understand correctly, you are saying that the driver is for the NI USB-6009 DAQmx device.  Is that what you are saying?
Have you looked at the Knowledgebase link that Dennis provided?  There is an example of code provided in that link.
Are you able to generate any type of signal using your USB-6009?
Can you post what you have implemented so far?
Message 33 of 55
(1,903 Views)
          i'll tell what exactly i'm doing now.......
1)  I have  a USB DAQ 6009 for generating the pulses for step motor......that step motor has a driver called DFR 1415A and the step motor is from vexta.......
     These r the components i have right now...... can u tell me how to proceed with the next step......
Message 34 of 55
(1,882 Views)
Sorry to ask more questions...
Does the driver (DFR 1415A) look like this?(the one in front of the motor)?
Message Edited by Ray.R on 05-03-2010 12:44 PM
Message 35 of 55
(1,873 Views)
I tried to locate the specs on the driver to find out details such as amplitude, period (frquency), pulse widths (high/low) / duty cycle.  I could not find anything on their website.
The only messages I got were the following:
No Results Found on "DFR 1415A*"
Your search - DFR 1415A - did not match any documents.
Suggestions:
  • Make sure all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
Do you have those specs?
Message 36 of 55
(1,869 Views)
               yes it is the sameone we are using it ....... i'll attach the datasheet of the motor ans driver..... pls tell how to configure everything
Message 37 of 55
(1,858 Views)
I'll try to have a look at the data sheets tonight.
Maybe Dennis will beat me to it.  He's the expert in motor controls using DAQs..
Message 38 of 55
(1,842 Views)
Photocoupler input, Input resistance 220, Input current 20mA maximum
Signal voltage Photocoupler ON: +4 to +5V, Photocoupler OFF: 0 to +0.5V
Step command pulse signal (CW step command signal at 2-pulse input mode)
Pulse width: 1μs minimum, Pulse rise/fall: 2μs maximum
Motor moves when the photocoupler state changes from ON to OFF.
Rotation direction signal, Photocoupler ON: CW, Photocoupler OFF: CCW
(CCW step command signal at 2-pulse input mode, Pulse width: 1μs minimum, Pulse rise/fall: 2μs maximum
Motor moves when the photocoupler state changes from ON to OFF.)
You will need to use the DAQ device to create a series of pusles from 0 to +5V amplitude with a minimum pulse width of 1 μs.
You connect the appropriate output of the DAQ device to the Pulse Signal Input Terminal (PLS) on the driver.
You need to provide a 24Vdc source (1.7A) to the Power Supply Terminals.
You need to do the other connections and configuration as explained in the data sheet.
You could use the Measurement and Automation Explorer to verify that the series of pulses look like what you wish to send to the driver.
You can look at the examples on how to generate pulses using the DAQmx devices.  Look in the Help Menu, and select Find Examples and do a search onthe keyword "DAQmx" and have a look at the Stimulus Signal Generation example.
Message 39 of 55
(1,837 Views)
          can u give me some more information about the previous reply
Message 40 of 55
(1,797 Views)
