internal error in transact.cpp line 2108
A complied program failed with an "internal error in transact.cpp line 2108"
Message 1 of 12
(4,954 Views)
Does it do it repeatably? Under what circumstances? What does the program do?
We need details...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(4,948 Views)
Hi!
My program fails with the same error.
It is repeatable:
I have a combo box in a subpanel vi. The combo box doesn't allow undefined values. When I roll down the combo box and then I press a button on my keyboard a pop up window appears with this error.
attica
Message 3 of 12
(4,743 Views)
Attica:
What version of LabVIEW are you using?. Please let me know so that I can reproduce this on my end.
Rudi N.
Message 4 of 12
(4,730 Views)
Hi
I use LV 7.1
attica
Message 5 of 12
(4,722 Views)
attica:
Thank you very much for getting back with me, I was not able to reproduce the issue. Please feel free to post the VI that reproduces this issue.
Rudi N.
Message 6 of 12
(4,699 Views)
Hi
Thank you for your help... Here are the VIs.
Attica
Message 7 of 12
(4,677 Views)
I tried to reproduce this but the file subvi.vi is missing.  One suggestion is to put the open VI reference outside of the while loop.  You should not open references, file, etc. while inside a loop.  I can't promise you that this will solve your problem, but it is a good programming practice and will probably save you a few headaches in the future.
Message 8 of 12
(4,658 Views)
Hi
Sorry for the missing file...
I was in a hurry when I made the VIs, that's why the funny mistake (loop with OpenReference) I have fixed it...
Attica
Message 9 of 12
(4,635 Views)
There appears to be several reports internally regarding this error and LabVIEW 7.1.  Most of them were fixed for LabVIEW 8.0.
If you could provide an error log file, I could match your error with the exact match, and potentially find a work around.  The error log location is shown here:
http://digital.ni.com/public.nsf/allkb/54E361E3FF477EC186256C320068184F?OpenDocument
Trey B
Applications Engineering
Message 10 of 12
(4,622 Views)
