interrupt states in a state machine
You find in the attachment two versions of my work : the first one with QMH and the second one with simple state machine
So i want doing the following process :
1--  i clic on "start measurment button", the state machine executes seq1 until seq4 normally unless i didnt clic on "stop measurement button" . i want when i press on "stop measurment button" the state machine interrupts the execution of the sequences and executes the "stop device state" and then returns the wait for user event state.
2-- i want to calculate the execution time of every state of my state machine
3-- i want that the current time to be dynamic  and  not fix
Plz heeelp
(2,175 Views)
Accepted by JASMIN185
What happens in the sequences steps? Currently you cannot abort during a state, just between states.
You can update the time display if each state uses the outer loop until a time has elapsed to go to the next state (or idle if the process is interrupted). If you want a continuous time display, it needs to be in a separate loop with a reasonable constant loop time.
A quick band-aid fix would be to pass the state through a select function before the case structure and switch to idle if the a button ins pressed. (f each state calls a lengthy subVI, you can jump through some flaming hoops with references to the time display, but I would not recommend that)
Get rid of the event structure!
(2,159 Views)
* in the sequences steps i send configuration to the instrument and i wait for it to finish calculating the leaking current and i display the result in the front panel . the same process is repetaed with seq 2 , 3 and 4 . parametres is the only thing that make diffrence betwwen sequences . and YES i want to ABORT the state execution once i clic on stop measurment button because every sequence state takes time ( about 1:30min) to finish executing
** i put the time display in a separate loop but once i clic on exit button the labview program continue its execution ( see image bellow )
***f each state calls a lengthy subVI, you can jump through some flaming hoops with references to the time display, but I would not recommend that) can u explain more ?
thank youu
(2,122 Views)
Put an event structure with a 500ms timeout and stop value changed event in the small loop and it will stop too.
(2,117 Views)
