intersection on XY graph
how to find intersection on graph entering   two points???
(5,404 Views)
Accepted by NikolaB
Two points make a line and the intersection is where the difference between line and data is zero. You probably need to interpolate. Seems simple geometry...
If you have a model for the data, you can do a nonlinear fit, and operate on the analytical curve, of course..
(Why are you doing "path to string" followed by "string to path"? Seems circular. Your VI uses 100% CPU when it is not doing anything)
(5,363 Views)
Of course in general there could be more than one intersection.
(4,911 Views)
