inverter + "continue if true" vs "stop if true"
I've noticed that a few programs (including those in the NI examples) use a boolean invert right before a "continue if true" to terminate a while loop instead of using a "stop if true".
As far as program flow goes, they are the same, but I wonder if there is any other difference between the two.
Message Edited by Sudhir Gopinath on 07-22-2005 06:27 PM
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(2,574 Views)
The only difference is the age of the VI. The "Stop if True" functionality is a fairly recent addition.
Mike...
LabVIEW Champion
(2,563 Views)
