invoke nodes no methods
As previous users have noted, the invoke nodes functions are not working on my VI after upgrade to labview 8.2.  I previously used these VI's with labview 7 w/o any problem.  I can do as has been suggested and switch methods, causing the nodes in the main vi to work, but when I try to do this for sub-vi nodes, I get a greyed out "no methods" message.  What gives?  Jonathan
Message 1 of 10
(6,809 Views)
Which methods are you looking for?
BR
Message 2 of 10
(6,786 Views)
I am very new to Labview.  I am not sure what the methods are... I am trying to modify a program provided to me by Horiba-Jobin Yvon, and used to control one of their monochromators via USB.  Thus, I don't know what the methods are or from whence they come.  All I know is that I place a node, select class (activex), and the options that I seek suddenly appear.  It also seems that if I just reselect the type of local going into the original nodes, the problem can be solved even more simply.
Message 3 of 10
(6,777 Views)
OK, so what exactly is (was?) the problem?
BR
Message 4 of 10
(6,774 Views)
I upgraded labview, and suddenly my monochromator control vi doesn't work.  I check the errors, and there are a bunch of errors saying "invoke node: invalid method" and "invoke node: invalid refnum class".  I assume that this is activex lingo that is beyond my 'turn the light on/off' knowledge of labview.  I seem to have blundered my way through that problem.  Now, I can't figure out how to make my little ni usb daq board work.  aargh.
Message 5 of 10
(6,772 Views)
Can you post the VI (or part of it)? Check out the example programs to know how to get USB DAQ to work with LV 8.2.
BR
Message 6 of 10
(6,757 Views)
Which USB DAQ device are you using?
NathanT
Message 7 of 10
(6,745 Views)
Hello!
I am having the same problems.
I was trying to open an .IOD from Catman (HBM) using an example VI (LV Open_IOD.vi) that I got from the guys from HBM. When I open the file, everything seems fine, but the VI doesn't work. The error messages are:
invoke node: invalid refnumclass
I using LV 8.2. Does anybody have an idea?
Thanks a lot!
Message 8 of 10
(6,689 Views)
You have to right click the reference (the upper blue green boxes that input into the nodes), go to "select item" and then select the appropriate option.  In my case, I had to select "mono refnum". This will automatically reset the nodes attached to the reference as well.  Does this help?
Message 9 of 10
(6,679 Views)
Oh yeah! That did solve the problem! Thanks a lot!
Alexandre
Message 10 of 10
(6,662 Views)
