is it necessary to upgrade from LV8.0.1 to LV8.2?
right now i'm struggling on whether i should uprgrade LV8.0.1 to LV8.2.
i'm just afraid that after i upgrade to LV8.2, whether my code written at LV8.01 can work well also?
and codes  i program at LV8.2 can be read at LV8.0.1?
and is it 8.2 give us better performance and less bugs?
thanks,
Wei
(2,633 Views)
Kind of depends on what you're doing, and what your budget is, which only you can answer. I know that there's plenty of people still working in 7.1 just fine, so it's not absolutely necessary to upgrade to 8.2 if your application runs just fine in 8.0.1.
Are there bug fixes? Yes, but 8.2 brings its own, just like all previous versions have.
Is it better performance? Yes and no. It starts up faster, but people have noted that the development environment can be slower in certain cases, and sometimes built applications are slower. This is all anectodal, so you should consider it that light.
Will your application still work in 8.2? Most likely yes. I only encountered one minor problem in upgrading my application from 8.0.1 to 8.2, and I had over 1200 VIs.
(2,608 Views)
thank you so much : )
very good answers 🙂
WeiSmiley Happy
(2,602 Views)
