is it possible to integrate fingerprint to a car park with LV
Sorry, i am new to LV. I would like to know Is it possible to integrate fingerprint device to lv car park?
Message 1 of 9
(3,566 Views)
hi dnssetup,
  Could you be more clear regarding your application?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 9
(3,559 Views)
Please define the input & output of DEVICE that you will use & what is expected out of LABVIEW to do?
Message 3 of 9
(3,551 Views)
Yes. I think LabVIEW can be used about all system developments.
1st, you have to choose hardware and then you can make source code of LabVIEW
Message 4 of 9
(3,540 Views)
I think he is trying to use a fingerprint reader for authorization.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 5 of 9
(3,529 Views)
sorry for not being clear.
Excually i want to develop a car park elevator using labview. And if the person wants to park the car, he would need to use his fingerprint to access the elevator and also remove the car, which would be done using LED. So, is it possible to use fingerprint device for it and is it possible to store the fingerprint in labview?
Thanks alot guys. Smiley Happy
Message 6 of 9
(3,493 Views)
Hi dnssetup,
  There are many things to be considered in your application.First one is your hardware or fingerprint reader,what is the output of it?how it can be interfaced to your system and how to build a program from the output if fingerprint reader is integrated to your system?Please be clear in the above things.
Srikrishna
Message 7 of 9
(3,483 Views)
Sorry again. The person should register with using their fingerprint. Than if the person want to park his car in the elevator, he uses his fingerprint to gain access. The fingerprint of the person would need to find a empty slot but it would be done using LED. Example, if it is the red LED means the slot is taken and if it is a green LED, that person car would be park there and the LED turns red. Instead using a Car Number Plate, I used a fingerprint reader. Is that possible?
Thanks again and for your patient
Mr.SrikrishnaNF
Message 8 of 9
(3,461 Views)
Message 9 of 9
(3,427 Views)
