is it possible to open multiple subvi's at the same time?
What error do you get, if any ?
Is the run-time engine of the corresponding version of LV already installed in the server ?
- Partha ( CLD until Oct 2027 🙂 )
Message 21 of 29
(1,621 Views)
Thanks again.
Not getting any error messge.Task manager shows as pgm not responding.
First the application run on the server.But after closing(i am not sure whether closed main vi b4 closing children...i forgot to inactive the main vi's close window button.)
For the second time can not run.So installed labview run time engine(am not sure about the version of the runtime engine)
Now not any labview exe can rub on the server....even a simplest one.
I am really confused ...dont know whats the reason.
Runtime engine should match with labview development version?
Message 22 of 29
(1,616 Views)
Yes, run-time version must match the LabVIEW development version.
Message 23 of 29
(1,609 Views)
Thanks a lotttt for the quick response.
My labview development environment is 8.0.1 under Windows XP..... and at the client site installed 8.0 RTE
The client side is having Windows server 2003.
Any compatibility problems regarding this?
Message 24 of 29
(1,603 Views)
You can get all run-time engines here.
Install the correct one.
Message 25 of 29
(1,597 Views)
I m not sure about the compatibility problem with Windows Server 2003. Please contact someone in NI.
Message 26 of 29
(1,594 Views)
Be aware that not all link are OK. If a link is broken look at the link and strip until it works and then browse the FTP site for the correct path.
I had the problem when downloading LV 8.2.1 RTE, LV 8.5 RTE was fine.
André (CLA, CLED)
Message 27 of 29
(1,588 Views)
Unfortunately, using LabVIEW with Windows Server 2003 is not officially supported by NI. Do you have another operating system you could use? Sorry for the inconvenience!
Amanda Howard
Americas Services and Support Recruiting Manager
Message 28 of 29
(1,573 Views)
Hi user_1,
I have the same problem, may I reference your code. If yes, please upload your code. Thank you very much.
Message 29 of 29
(1,385 Views)
