is it possible to set the background color of a chart or graph to be transparent?
thanks
(4,890 Views)
yes
(4,887 Views)
Accepted by lksusier
Yes it is.
Select  Tools palette (View>>Tools palette) and set the chart background as well as the control to transperent.
Message Edited by Vsh on 11-10-2009 12:19 AM
(4,886 Views)
Yes it is possible to do so. Goto View>>Tools Pallete. This will open up a tools pallete which you can use to modify the colours and other viewing options of graphs and anything else on the front panel.
For your purpose u select the background of the graph and  click on the "set colour squares" present in the lower bottom corner of the pallete. This will open up a whole range of colors you can select for the purpose. There in the black and white strip of colours, there is a box titled "T" on the right most corner. Select that "T" and your background color will go transparent.
Have a nice day. Happy codings.
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
(4,877 Views)
Lesson: coffee can wait, But Solution wont.
Moral: If you know the solution, post it first then take coffee.
Regards
Asad Tirmizi
Design Engineer
Using LabVIEW 8.2
(4,875 Views)
