is there a fully functional VI for TKTDS 420A for 4 channel
I need a full functional VI for my TKTDS 420A,
and i need it to be real-time
am i able to create it?
or there is some subVI that i able to use
(2,372 Views)
There is a LabVIEW instrument driver for the device that you may be interested in; otherwise you should be able to use serial or GPIB commands (or whatever connectivity your instrument provides) as defined by your instrument to define your desired communication. The driver can be downloaded from the following site (you may be prompted for your NI profile information; if you do not have a profile established you can create one when prompted and you will be linked to the download page thereafter):
http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/39b8cf2494ba0b67862568ab005fb89c?OpenDocument
JLS
Best,
JLS
Sixclear
(2,372 Views)
