Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
is there a string comparasion function?
Se
Member
04-03-2003
09:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to compare a list of strings to see wether they are the same or not. for example: If they are the same then I should do this and if they aren't then I should do that. Is there any such function in labview?
0
Kudos
Message
1
of 2
(2,627 Views)
Reply
Re: is there a string comparasion function?
ian_fung
Trusted Enthusiast
04-03-2003
11:16 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
How about using the "=" function in comparison pallete?
as it is a polymorphic function.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
1
Kudo
Message
2
of 2
(2,627 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
