is there a way to convert decimal or hexadecimal string to bcd on labview 8.0 or 7.1??
i am trying to convert user input data to bcd data. is there a way to do this besides converting each individual data bit to binary?
(4,817 Views)
How do you want the data represented in memory? Because the BCD code only takes 4 bits there are several options:
  1. One byte per digit with the unused bits set to zero
  2. One byte per digit with the unused bits set to ones (hardly anybody does this anymore)
  3. Two digits stored in each byte
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,812 Views)
I'd go with option 3 please
(4,789 Views)
Hi kukla,
have you tried the very easy formula bcd = 16* number2 + number1 ???
Number1&2 should ofcourse not exceed the range of 0 to 9, as you work here with decimal numbers...
(4,782 Views)
