is there a way to recover a damaged VI ?
Using current version of labview and had just changed the Icon for the VI I had finished then I saved the file and closed it.
When I tried to open it LabView gave the error front panel seems to be missing and will not open the file.
Is this recoverable or am I starting over ?
Message 1 of 9
(4,807 Views)
Just pull out the latest version from your repository. No need to start over. What? You don't use version control?!?
Sorry but if there is another way to recover it I don't know how. Someone else will reply if there is. I just wanted to express the importance of version control. Programming without version control is like driving without a seatbelt. There could be issues down the road.
LabVIEW 2012
Message 2 of 9
(4,801 Views)
Did you try a search? This is like the umpteenth time this same exact question has been asked. The answer is always the same.
Message 3 of 9
(4,793 Views)
Yes we did a sirch, there is only one copy of the VI and it crashes LabView when I try to one in now.
Message 4 of 9
(4,787 Views)
Hi steppir,
can you upload your damaged vi?
Mike
Message 5 of 9
(4,759 Views)
Accepted by steppir
Thanks for trying to help, I have now recreated the VI and sense it crashes LabView I have sent a copy of the bad file with the crash report to NI in hopes they will fix the hole I fell into.
Message 6 of 9
(4,730 Views)
While you are waiting to see if they can fix it you might want to read this.
LabVIEW 2012
Message 7 of 9
(4,717 Views)
This actually brings up an interesting point, I have noticed that LV2011 seems to be trashing VIs on a fairly regular basis. Has anyone else noticed this? When it happens, the VI still links in correctly wherever it's being used, but you can't open its front panel.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 9
(4,707 Views)
Yep, just happened to me as you described.  The Vi is on the main Vi bock diagram and I can't open the front panel.
That's why I'm reading this thread.
Oh yeah, I am running LV 2011.
Message 9 of 9
(4,624 Views)
