is there any list of sensors' vi(s) already exist in Labview?
Basics of NI Robotics for further reference:  http://www.ni.com/video/1035/en/
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 21 of 26
(780 Views)
NIquist:
i did tell that im using it, as you can see at the first page.
im already did some work with the robot, but all i want now is to attach to the robot 1 or more of those sensors and that the robot will react to data that he gets from them(the sensors outputs)
Message 22 of 26
(773 Views)
Ahh, I just thought you wanted information in general about the sensors that would work with NI Robotics, I didn't realize you had hardware.  Did you find the NI Robotics Module?  It should have everything you need to read the robot's sensors and control its motors, etc.  Looks like a fun toy, I wish I had one!
Message 23 of 26
(748 Views)
yea, im using the Labview Robotics and i do control the robot with it, but i want to connect more sensors to the robot.
my questions are:
1. if are they any already-made VIs for the sensors that i mentioned?
2. what will be the best way to connect those sensors to the robot, so i will have access to it's data through Labview?
thanks
Message 24 of 26
(743 Views)
Of course there are no ready made VIs for those sensors.  They are just integrated circuit chips!  They don't even come with a way to power them much less communicate their signals.  You have to design and build the support circuits and a circuit board to mount them and then write DAQ code that interprets the voltage outputs of those chips into real-world units.  This is called Engineering.  Smiley Wink
Message 25 of 26
(725 Views)
well, ok, thanks
Message 26 of 26
(713 Views)
