is there any way of getting the label of any variable as a string ?
After I label any indicator (or whatever) is there a function that reads that label and outputs a string ?
Message 1 of 18
(5,043 Views)
You can read the "label.text" property.
Message Edited by altenbach on 04-20-2009 03:27 PM
Message 2 of 18
(5,036 Views)
Ok but in order to use this i need to link the property node to that variable. What I was thinking is something like a SubVI or a structure that for whatever variable (labeled) as input it outputs the label as string. (something that will autolink my property node to the input).
Message 3 of 18
(5,023 Views)
You could use Altenbach's code as a VI and wire in a reference to the property node.  Does that make sense or do you need more help?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 4 of 18
(5,011 Views)
I think i need more help.
I created a suvbi that looks like Altenbach's code, i connected a terminal to the indicator, but whenever I use that subvi and input a variable, the label does not pass to the indicator in the subvi so as an output i get the label of the indicator inside the vi.
Message 5 of 18
(5,008 Views)
Also I'm not sure what that reference should be. Can a reference be a let's say integer type indicator (control) ?
Message 6 of 18
(5,005 Views)
Accepted by zmuccelmic
Code and image attached (I'm using 8.2)
First of all, the reference is a control -- it's connected to the connector pane.
This will only work for numerics.  I figured out a way to get it to work for generic references, but I didn't do it yet and it's probably too much work unless you really need it.  There might be an easier way...
When you this subVI from another VI, you would connect a reference to the object whose label you want to the input terminal.
Let me know how it goes...
-Matt Bradley
Message 7 of 18
(5,001 Views)
If you need one for strings, it's not that hard.  Minor changes to the code.
-Matt Bradley
Message 8 of 18
(4,999 Views)
It seems to do the job. I have no idea what those control refnum are but hopefuly I'll figure out eventually (I just started using LabView 3 days ago 😞 ).
 Thank you !
Message 9 of 18
(4,994 Views)
It works if for a certain variable i create a reference first and input that reference to that subvi. Is there any way that i can just input the variable ? (I do have a lot of them and I dont want to create references for every one of them.)
Message 10 of 18
(4,990 Views)
