jki event time response
I discovered jki a while but, never had opportunity to use it. Today i am trying to see how it works
but i encounter some troubles when task are return on themselves a mount of time so idle case is not considerate
before the end of this taks: for example waiting for an instrument before measure  get ready.
His there a way to have a  shorter UI response time
here a basic example in 8.6  it could takes between 0 to 3s to stop
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,222 Views)
Accepted by tinnitus
I often force it to go through the Idle state when I'm waiting like this.  It's been discussed on the JKI forum here.  You'll need to use a timeout value <= 0 for this to work.
Message Edited by jcarmody on 12-04-2009 09:56 AM
Jim
(3,208 Views)
hello,
thank you for your response, you would like to say >0 .
Regards
Tinnitus
Message Edité par tinnitus le 12-04-2009 10:51 AM
Message Edité par tinnitus le 12-04-2009 10:52 AM
(3,195 Views)
