join numeric with join numbers function
Hi !  a small question from a guy that didnt use labview for a while !
i need to use the join number function to join two DBL number A and B to form a new number A.B, just like the join numbers function
in the example i would like the results after the join number function to be 1.5
however i understand that the function merge bytes/words together and the result is far from what i expect ....  any ways to
A and B are extracted from modbus READ register command and are unsigned 16 bit
seems easy enough but i need a good refreshment on how those bits, bytes and numeric works together..   doh !
thank for everyone involved, Kudos to all labview champions!
Message 1 of 23
(10,558 Views)
Hi yan,
it seems you really need a refreshment on all those bits/bytes/numeric representations 😄
Typecasting floats (DBL) to U16 will probably never result in the desired value.
Why do you convert your U16 modbus values to DBL anyway? Stick with U16 and you will have no problems using JOIN or any other bit-banging function...
Message 2 of 23
(10,551 Views)
then why do i get 65541 as the result?
Message 3 of 23
(10,538 Views)
Hi yan,
because 1*2^16+5=65541.
Which result do you expect?
Message 4 of 23
(10,531 Views)
You mean 1 and 5 should give you 15?
Message 5 of 23
(10,526 Views)
Hi yan,
if Anands idea might be your goal you should use some simple math instead: 1 * 10 + 5
Message 6 of 23
(10,523 Views)
thats why i need the end results to be in DBL, caus i want 1.5 as the results
not 15
Message 7 of 23
(10,512 Views)
Hi yan,
so the simple math changes to a + b/10 with a=1 and b=5. Where's the problem?
The problem seems so simple, but you can not provide any good information/description of your logic/task. What does the manual of your device say about those numbers?
Message 8 of 23
(10,509 Views)
the two register i am reading from the modbus device gives me a ppm values of a gas detection system
A being before the comma
B being after the comma
in the format A.B ppm
to log the values red by the system i need to combine them together before and then log them, display them in a graphic..etc
Message 9 of 23
(10,507 Views)
Accepted by topic author yandub666
Hi yan,
as your description still isn't clear in all details I provide two options, see which one fits your needs:
Message 10 of 23
(10,502 Views)
