join numeric with join numbers function
Then convert both the numbers to string and Concatenate them along with the comma.
Message 11 of 23
(3,750 Views)
kudos to both of yaa!
never been so easy to earn kudos i bet
Message 12 of 23
(3,734 Views)
GerdW's option (a) can only be correct if part B has only 1 significant digit, i.e. the number B represents tenths.
We need to know how many digits are represented to the comma's right side.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 13 of 23
(3,733 Views)
it should go into the part per billons, so B can get as much as 3 significant digits
Message 14 of 23
(3,729 Views)
Hi yan,
"as much as 3 significant digits"
Again: What EXACTLY does the manual say about that topic?
Message 15 of 23
(3,725 Views)
In LabVIEW board getting our reply Marked as a Solution is more valuable than getting Kudos (Ofcourse Kudos make you happy) becuase only one gets that Smiley Wink
Message 16 of 23
(3,722 Views)
i have yet to clarify that with the guys over at MSA but you can see for yourself
http://s7d9.scene7.com/is/content/minesafetyappliances/ModCon%2075%20Instruction%20Manual%20-%20EN
page 62 are the description of the combination of both number to build the final reading
Message 17 of 23
(3,718 Views)
Well, this doc doesn't explain much. How they can represent 1,05 differently from 1,5?
Of course, GerdW's option (b) may be the correct one, but the manual gives no clue about this.
Paolo
Message 18 of 23
(3,709 Views)
the display of the gas detector never go beyond one significat number, so i assume that i wont have more than one number after the comma
ill be back if somethin goes wrong and give you an update!
Message 19 of 23
(3,706 Views)
Hello!!!
I have a similar problem in my vi.
I need to read a temperature of 20,91ºC and from the  holding registers i get the array:
holding register
i think the first cell is supposed to be the 20 and the second one 91 but i dont know how to program to convert the array into the real value.
Anyone can help me please?
Message 20 of 23
(3,635 Views)
