k mean:: how to find the clustred data;:: or how to assign number t0 each group of data
hi member
i have download the LabVIEW Machine Learning Toolkit https://decibel.ni.com/content/docs/DOC-19328
i want to excute the K mean algorithem to cluster the image in two group or three or more
the problem is how to find the result i mean the clustred image', the image that contain 2 or three intesity value only
or how to aasign a 1 vlaue to all intesity that
belong to cluster one and 255 to data that belong to cluster 2
so that the image look like binary image???
a my vi below
best regards
(4,346 Views)
Hello saliim,
From the k-mean vi we get two outputs, one of them is a 1d-array and the other is a 2-D array. I am trying to understand what are you trying to do with these outputs; are you trying to modify these arrays (Add elements, edit elements)? Could you explain how you are getting data  right now and how you want to get it?
(4,305 Views)
dear
i try to applay the k mean to  2d image and find the result
shown below with k=2
please help
(4,293 Views)
hi saliim,
have you tried an histogram?
Based on this, thats what I would do for k=2
Alex
(4,274 Views)
Accepted by saliim
my post before showed how to set the threshold manually using the graph's cursor.
here's the automated k-means version, using the toolkit's .vi
Alex
(4,258 Views)
