01-07-2008 01:47 PM - edited 01-07-2008 01:47 PM
Hi Noam,
One thing you can try is to use a different format, with commas between the channel numbers, to send the (@X:Y) list. For example, instead of ":ROUT:SCAN:INT (@1:10);", try ":ROUT:SCAN:INT (@1,2,3,4,5,6,7,8,9,10);". Also, make sure that you are selecting the Internal scan mode in Configure Scan.vi, because the NI Spy log indicates on line 15 that the mode being selected is None.
The attached Configure Scan VI should automatically format the list with commas. Try running this VI and let us know if this makes a difference.
Rima
01-09-2008 03:54 AM
01-10-2008 10:03 AM
01-13-2008 03:35 AM
01-14-2008 11:46 AM
01-14-2008 11:58 AM
Hi Noam,
Somehow I posted the wrong VI, and I apologize for that. This is the VI I mentioned earlier.
Rima
01-16-2008 05:15 AM
01-16-2008 05:39 AM
01-17-2008 06:00 PM
Hi Noam,
At this point, it seems that this issue is specific to the instrument, so it would be best to contact Keithley. Good luck!
Rima
01-20-2008 03:23 AM
