keithley 2000 starting channel
Hi Noam,
One thing you can try is to use a different format, with commas between the channel numbers, to send the (@X:Y) list.  For example, instead of ":ROUT:SCAN:INT (@1:10);", try ":ROUT:SCAN:INT (@1,2,3,4,5,6,7,8,9,10);".  Also, make sure that you are selecting the Internal scan mode in Configure Scan.vi, because the NI Spy log indicates on line 15 that the mode being selected is None.
The attached Configure Scan VI should automatically format the list with commas.  Try running this VI and let us know if this makes a difference.
Rima
Message Edited by Rima H. on 01-07-2008 01:47 PM
Rima H.
Web Product Manager
Message 21 of 30
(3,439 Views)
Hi Rima,
First of all, I use "internal" scan mode. At that time I probably forgot.
Second, where do I make the change of (@1,2,3,4,5,6,7,8,9,10)?
Last, how do I use the VI you sent me? I get an error massage saying that the VI does not belong to the library it is in. (error massage is attached)
thanks,
Noam.
Message 22 of 30
(3,421 Views)
Hi Noam,
Try the attached VI.  The VI should implement the command with the commas automatically.
Rima
Rima H.
Web Product Manager
Message 23 of 30
(3,396 Views)
It says I need LabView 8.5 and I use LabView 8.0.
Is there a way to still use it?
Thanks again...
Message 24 of 30
(3,378 Views)
Here you go, saved back to 8.0
Message 25 of 30
(3,357 Views)
Hi Noam,
Somehow I posted the wrong VI, and I apologize for that.  This is the VI I mentioned earlier.
Rima
Rima H.
Web Product Manager
Message 26 of 30
(3,353 Views)
I tried using it in 3 different drivers which are available in NI site (2003, 2004, 2005). To what driver was this VI written?
All of them gave an error about "Error Query.VI".
Anyway, there is no input selection, only 2 outputs, so I can't put the "intialize.VI" before "configure", and as for the settings, I changed them in your VI itself, I think it's o.k.
The result is that the Keithley starts scanning but never stops and I never get output so I don't know it's influence.
Message 27 of 30
(3,335 Views)
O.K. I understood my mistake. Your VI is just fine and working with 2004 driver.
Anyway, it didn't solve the problem. It still starts measuring from the 2nd channel.
Message 28 of 30
(3,331 Views)
Hi Noam,
At this point, it seems that this issue is specific to the instrument, so it would be best to contact Keithley.  Good luck!
Rima
Rima H.
Web Product Manager
Message 29 of 30
(3,295 Views)
thank you anyway.
Message 30 of 30
(3,269 Views)
