key down event on a graph
Hi everyone,
I am trying to trigger several events (autoscale, zoom) on a graph by key down event when my mouse is on the graph. Is that possible?
I attached an vi to demonstrate the issue.
(3,715 Views)
Accepted by Xiang00
Hi Xiang,
a graph usually is an indicator, so it might be hard to receive UI events meant for controls…
You can use one event case to detect "mouse over graph". Using this information you can use another event case to receive all key input events of the whole VI frontpanel, but only handle them when mouse is over the graph…
(3,708 Views)
Dear GerdW,
Thank you very much for your promet reply.
With your advice I solved my issue perfectly.
Xiang
(3,689 Views)
Hi Xiang00,
I am trying something similar, but I could not follow this thread. Do you mind sharing your code in 2014 version? My goal is to zoom in/out the y-scale of a graph with the mouse scroll.
Thanks!
(2,389 Views)
@rpicazof wrote:
Hi Xiang00,
That is a totally different problem.
Use an event structure to catch the Mouse Wheel event on the VI's pane(s). Then use the graph's property nodes to change the graph's scales.
(2,366 Views)
