kindly tell how to use the single value from an array with 0 index
(2,838 Views)
Hi narula,
ever tried the IndexArray function?
(2,825 Views)
Accepted by narula
Hi
Yep, use Index Array as Gerd says. Also, using the context help (<ctrl> + h) and looking through the array palette will help you get an understanding of what each VI does.
This is fundamental LabVIEW stuff, perhaps you'd be better spending some time going through the basics.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(2,813 Views)
thanks working
(2,798 Views)
