kindly tell how to use the single value from an array with 0 index
(2,874 Views)
Hi narula,
ever tried the IndexArray function?
(2,861 Views)
Accepted by topic author narula
Hi
Yep, use Index Array as Gerd says. Also, using the context help (<ctrl> + h) and looking through the array palette will help you get an understanding of what each VI does.
This is fundamental LabVIEW stuff, perhaps you'd be better spending some time going through the basics.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(2,849 Views)
thanks working
(2,834 Views)
