04-22-2010 01:45 AM
I am stuck up in a problem. I have a very huge testing software written in lab view 4.0 in Win 98 and Ni daq ver 4.8.5. Lab view 4.0 accesses daq (ISA based) through CIN. Similarly it also had an ISA GPIB card. Now as the ISA has been obsoleted and i want to upgrade to PCI cards. I have used the same image of the OS system with the same LV4.0 folder and all. The software was compiled and an exe files was built in LV 4.0. This exe files calls various VIs placed in different folders during run time. Now after upgrading to PCI cards, the CINs and the lower level VIs are not linking up with the driver. I have tried various verisons of No daq from 4.9.2, 5.0.3, 5.0.5, 6.0, 6.1 6.5.0, 6.7 etc. driver versions like 5.0 are successfully installed and configure the device however, in lab view VIs the broken arrows are shown giving the error of missing CIN or fatal errors in various cases. Now i have an idea that if i maintain the exe file and i just upgrade the standalone VIs in Lab view 7.1 or later would it be possible that the exe built in 4.0 can dynamically call / load the VIs update din Lab View 7.1 or later. Similar case for GPIB.
04-22-2010 02:46 AM
Your request is somewhat confusing. What kind of PCI card are you using, and have you checked which DAQ version this card are compatible with. Let us start in that end. And let us also assume that you use Labview 7.x. You will in any case not be able to call a VI made in 7.x from a 4.0 application
04-22-2010 02:51 AM
The problem is that driver version 5.0.5 is compatible with Daq card that i am using (DIO-32HS) but i am unable to use the Lab View 4.0 VIs that give error of broken arrow.
04-22-2010 03:24 AM - edited 04-22-2010 03:25 AM
I can tell you so much that your firm has put it self in a very awkward and dangerous situation by not upgrading the system. At some time your system will brake down. You will not be able to find parts. The production will be halted. And that will cost much more than the money saved on not upgrading. The sky is the limit. Why are your firm still using Labview 4.0 then you have never versions?
04-22-2010 03:32 AM
04-22-2010 04:28 AM
04-22-2010 05:28 AM
