labVIEW NXG with arduino
hello friends !
i want to convert to LabVIEW NXG but i have some questions , can i work with same Features for The old generation from labview and can i use the same Libraries and Toolkit like control design and simulation or linx (arduino)
(5,506 Views)
Accepted by laith_Ismail
Hello Laith,
At this point in time, I think you may not want to migrate your code to LabVIEW NXG, as the toolkits that you are using may not all be supported yet.  You can check here to see what toolkits are supported/are planned to be supported in LabVIEW NXG 1.0 and 2.0 beta.  It looks like LabVIEW Control Design and Simulation Module is not supported in either LabVIEW NXG 1.0 nor LabVIEW NXG 2.0 beta.
As for LINX, I would post on LabVIEW MakerHub forum.
Clemens | Technical Support Engineer | National Instruments
(5,431 Views)
thank you very much ...... but my question here why NI didn't support these tools in labVIEW NXG 1 or 2 ?
(5,424 Views)
It's a completely new environment.  It is going to take awhile to reconstruct all of those libraries in the new environment.
(5,419 Views)
