labVIEW driver for SR860
Can anyone suggest me to get the LabVIEW drivers for SR860 Lock in Amplifier model ???
(4,466 Views)
There's a driver for the SR865.  All SR LabVIEW drivers are listed here - https://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/n2:RS.stanfordResearch,ssna...
Looks like the SR860 is new and there might not be a driver yet.  Their product page provides an EXE and its source code, which you could easily translate to LabVIEW. See, https://www.thinksrs.com/products/sr860.html
For a prebuilt LabVIEW driver it looks like you will want to contact SR directly and see if they are working on one or if the SR865 driver (or other) is compatible.
Craig
(4,416 Views)
Thanks ACTIVE PARTICIPANT for your suggestions. i will try using the SR865 LabVIEW drivers
(4,354 Views)
