labview 2007
i am designing a DMA controller 8237A using labview 2007,for my project i need logic block which should activate for the every logic high output,how can i design the block
Poornima HS
poornimaaug10@gmail.com
(3,156 Views)
Accepted by labview 10
Can you define more about what is the function of the block?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,143 Views)
I am not familiar with the 8237A.
Can you provide more details?  Especially how LabVIEW Interfaces with it.
A side note:  There was no version called LabVIEW 2007.  In 2007, you most likely had LabVIEW8.5 or maybe it's predecessor 8.2.
(3,128 Views)
