labview 2010 no device found
I am upgrading a windows XP 32 bit lab to a Windows 7 64 bit Enterprise lab using Tektronix TDS1012C-EDU Scopes. When I launch LabView 2010 the software cannot find the scopes and display a message "No devices found". The scopes show up in device manage and in windows devices. I am have upgraded to the latest version of NI-Visa and installed all the critical updates for Labview 2010. The scopes are connected via a USB connection. I contacted Tektronix and they had me upgrade the bios in the scopes. Still nothing. Any help is welcome.
Message 1 of 9
(3,713 Views)
Do you have National Instruments Measurement and Automation Explorer installed (if you installed the NI drivers it should have been)? If yes, look to see if it can see the instruments, and if it does, see if the names or aliases are what is expected in your program. Of course, if the USB are being used as serial ports adapters then you may not see them. If they are, then quite possibly the settings or comm port associations have changed.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 2 of 9
(3,709 Views)
Lets see what happens if I shake the 8-Ball, Sometimes it works
~~~~~~~~Oh 8-Ball ~~~~~~~~
Is the OP using the IVI driver without the IVI compliance package? http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=18782
(Whats up with links Jordan?)
Message 3 of 9
(3,695 Views)
Thanks.. I cannot see the scope in any National Instruments product. The connection is not serial to USB but USB 2.0 direct. I installed the IVI compliance package when I upgraded NI-VISA.
Message 4 of 9
(3,687 Views)
Interesting,
The USB port is for a data storage device on the TDS 1012.  It does NOT support remote access to the device.   Do you have the TDS2CMAX accessory installed?  That would allow remote operation via RS-232 and GPIB on this model
Message 5 of 9
(3,677 Views)
Hey Jeff,
Are you having issues with links? It looks like you were able to successfully create a hyperlink.
Jordan
Message 6 of 9
(3,674 Views)
Jordan.
My appologies, it's not ALL on your end.  I Kicked off a new contract (Again) and apparently don't have the latest and greatest flash player.  Of course, if the warning didn't show up Way Way Down off the screen
it would be easier to find
Message 7 of 9
(3,668 Views)
But, I'm all better now.  Sorry to hijack the thread.  Jordan, Feel free to blow off the noisy posts after you see what I mean so Li can work on it.Smiley Wink
Message 8 of 9
(3,663 Views)
My scope is a model C and uses USB for data transfer.
Message 9 of 9
(3,651 Views)
