labview 2010 reinstallation problem
Hi, all. I am new at here.
I hope you all can help me regard to some problem of installing labview. I attached some screen shot during the error occurred. The main issue is I using the same labview installer to install the labview to my personal laptop and it's work but when I install to my company CPU, it did give me much error. Besides,  I had turn off all the window fire wall, but it's still cant work.
More on my situation:
I doing this reinstallation to my company CPU is because the previous labview program installed had corrupted. Therefore,  I already fully uninstalled all the labview program and reinstall it currently. However, I am facing the errors shown in the pictures.If I am not mistaken, the previous labview version that installed  is same as the version that I install to the CPU now.
(2,796 Views)
Accepted by app_lee
You might want to uninstall all NI modules and do a reinstall. Typically, I usually like to start from a fresh Windows installation (or revert to a clean Windows restoration point) when these kind of problems occurs.
(2,777 Views)
Also, do you have multiple versions of LabVIEW on the computer? I always try to keep one version installed.
(2,777 Views)
your mean for start from a fresh windows installation is that I need to format my pc?
I am not sure my company having multiple version or not due to I am still new in my company.
If I want to reinstall from a higher version of labview to a lower version of labview, is it possible?
However, thanks for your answer. I will suggest your idea to my supervisor.
(2,765 Views)
You don't necessarily need to reformat your hard drive, but you can if you wanted to reinstall Windows fresh. Otherwise, if you have Windows backups, you can restore back to a known good version. You can check how many version of LabVIEW are installed on your PC by going into the Programs -> National Instruments folder and view the different LabVIEW versions installed. I don't like to go back in versions of LabVIEW as I always had problems with drivers and hardware compatibility. If you ever want to revert to an old version, I would recommend to install on a fresh Windows.
(2,749 Views)
