labview 2010 vs 2009
Dear LabView experts,
I would like to control a stepper motor/stepper motor controller using a CAN bus card.  I downloaded a CAN library and examples from a CAN card/stepper motor controller company.  The examples opened fine using LabView 2009, but, got broken wires when opened in LabView 2010.  What do I have to do to address the broken wires in LV 2010?  Thanks!
phsieh2009
(2,181 Views)
Have you clicked on the broken arrow and red the message as to why it is broken? That would go a long way in determining what your problem is. More likely than not there is a driver or some other code that is installed for 2009 that is not installed for 2010. However without more information it is impossible to give you any suggestions to resolve your issue. Your question is about as useful as going to a auto mechanic and saying "My car doesn't work, fix it." Kind of hard to do that without knowing what the problem is in the first place.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,176 Views)
