List Folders not working in Windows 7 (error 7)
With Labview 2011 installed on a computer running Windows 7 Pro, the "List folder" function under advance file I/O fail with an "Error 7" message.
The same function  worked fine  when I used Labview 2011 installed on a XP computer.(same hardware)
(3,059 Views)
Have a look at the following:
http://digital.ni.com/public.nsf/allkb/CA516897BD8A80B8862578A90056DFD7
What happens after you turn off UAC?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,056 Views)
Thank you for the reply, I found this link during my search for a solution. Unfortunately it did not work. Also this seems to be for a mapped network drive.
(3,037 Views)
I did find  a really odd thing though. When I list the c:\ drive it works fine. The drive I use for my application is w:\
(3,035 Views)
You didn't answer my question: have you tried turning off UAC? What happens then?
Adnan Zafar
(3,027 Views)
It made no difference.
 I know now what the problemm is, but have no solution. The computer is configured as a dual boot XP and Windows 7. The specific drive is shared between the two operating systems. I added a new drive and format it with Windows 7, with this drive the function works ok
(3,016 Views)
