xyz power spectral intensity plot
Hello forum,
I am acquiring 8 signals and sending them to the power spectral density subVI. I can put this out on a waveform graph and clearly observe the power spectral density of each signal. I wantedt to know if there is a way to have this plotted on an intensity graph, where the signal number is the x-scale, frequency is the y-scale, and the signal strength (in dB) is the intensity (z-scale). If not possible then is there a way to save the calculations from the power spectral density subVI in an excel spreadsheet where each column will represent the frequency and it strength?
cheers,
(2,668 Views)
Intensity graphs use the indexes of a 2D array of data as the X and Y axis values.
So your signal number can easily be the x-axis.  If your data frequencies are integers, they can be used for the y-axis. If not, you can still use the index of the spectral density array as the axis.  To scale it as frequency you would need to hide the integer axis and place a slider or some similar control to represent the actual frequencies.  It can be tedious, but it is not particularly a difficult thing to do.
Lynn
(2,659 Views)
